RS4 Top Speed
RS4 Top Speed
Did some runs this weekend while the car is still std.
4th gear max was 138 mph on the Speedo and 5th went straight to 169-170 mph. Went into 6th gear but the car just stayed at 170 mph and would not pull anymore. I could feel the drop in power as i hit the gas in 6th.
I read somewhere that the car was only limited in top gear and seems to be true.
I will do some more runs week after next when the limiter's been removed with some video footage.
RE: RS4 Top Speed
I believe its limited to 7K rpm in top?
I've observed the same behaviour.
Out of interest, who are you getting the rev limited removed by?
I'll take a PM if you'd otherwise not say.
Cheers.
Cheers.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Re: RE: RS4 Top Speed
You have pmSR71 wrote:I believe its limited to 7K rpm in top?
Cheers.
RE: Re: RE: RS4 Top Speed
My limiter is removed, however I have not tested it yet.
Germany sometime.
Germany sometime.
This is what im hoping for once the limiter has been removed/increased.marin wrote:http://uk.youtube.com/watch?v=VH7obaj5Ekw
t_urbo wrote:marin wrote:http://uk.youtube.com/watch?v=VH7obaj5Ekw
See, I didnt make it up about 187 gps verified!!
djcevo,djcevo wrote:t_urbo wrote:marin wrote:http://uk.youtube.com/watch?v=VH7obaj5Ekw
Is your car modded at all, bar the limiter removal?.Also, have you had a go at an M5 at all round the ring?.I still miss the performance hit of my M5, regards, SIMON.
From what i understand the top speed will be the same regardless of what ecu mods are made, this is because there is no significant additional BHP gain at higher rpm.Dom81 wrote:Is this stock, or with some mods?djcevo wrote:The top speed on my B7 has been a gps verified 187 mph!!
To increase the maximum top speed mechanical changes are required and im not talking about just an exhaust.
Had 172mph (timing beam) in 5th gear & was probably about 50-100rpm from the rev limiter in 5th. My car has been de-limited & i hope to get a better idea of the VMAX in 6th Gear on the Continent this week.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
The car has been remapped and delimited, was RR (I know there can be discrepancies with these) but came out with a healthy 437.6 IIRC.SimonH wrote:djcevo wrote:djcevo,t_urbo wrote:
Had a burn up with the burgundy press M5 estate which I know is slightly heavier than the saloon but there was bugger all in it to 140/150mph.
Don't know whom had it but they were driving mental.
D
Users browsing this forum: Google [Bot] and 104 guests
