S3 Performance loss..please Help.
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
squale
Post by squale » Sat Aug 18, 2007 1:22 pm
Hello,
I would to expose a problem which i experience with my S3 as i am becoming desperated.
The car : 2002 225 S3, ABT remap, stainless steel catback exhaust, silicone induction hose, cotton panel air filter in standard airbox, which was running very fine until the following pb occured:
When I log the boost with VAG COM, It never reach the target boost: i.e: 2300 mbar instead of 2500mbar for example between 3000 rpm and 4000 rpm.
Moreover, I especially feel a strong loss of power of the car, especially in recovery, and what is strange it is on motorway in 6th gear for example, when I floor the gas pedal, the boost sometimes stagnate (i monitor with a gauge) and pass suddendly to full boost (1.3-1.4bar,but not to the requested 1.5 bar), this stagnation problem seems to disapear when unplugging the n249, but despite everything, the performance still remains poor.
Another phenomenon: sometimes when I release slightly the gas pedal , i feel the car pulling stronger..
I guess that all this must be dependent but I despair to find a solution now.
I replaced with new oem parts : dump valve (710N), the n249 and n75, as well as the suction pump (small Y of plastic) under the intake manifold (which was leaking oil). I also inspected all the hoses and connections I do not find any leak.
Thank you for your assistance.
BlackS3
RE: S3 Performance loss..please Help.
Post by BlackS3 » Mon Aug 20, 2007 9:55 am
Have you checked the MAF??
squale
Post by squale » Wed Aug 22, 2007 7:08 pm
I checked it yes, values between 180-195 g/s, is it normal ones ? Could the maf can create such problems ?
BlackS3
Post by BlackS3 » Fri Aug 24, 2007 2:54 pm
Shouldn't the MAF values usually be 230-250 g/s. Don't quote me as I'm sure this figure is different for different models but a fault I had with MAF was spurious readings from it.
squale
Post by squale » Sun Aug 26, 2007 1:31 am
BlackS3 wrote:Shouldn't the MAF values usually be 230-250 g/s. Don't quote me as I'm sure this figure is different for different models but a fault I had with MAF was spurious readings from it.
The maf has been changed, no improvements, or slightly...
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 40 guests
