Todays scan results
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Philws4
Todays scan results
Post by Philws4 » Sat Aug 25, 2007 11:03 am
Did a full scan this morning and got this!
17862 EGT SENSOR 1 SHORT TO GROUND
P1454-35-10
17521 OXYGEN SENSOR B1 S1
INTERNAL RESISTANCE TOO HIGH
P1113-35-10
17539 OXYGEN SENSOR B2 S1
P1131-35-10
Any ideas bearing in mind that both oxygen sensors where replaced in May this year and i have only covered 1100 miles since!
However the sensors are NOT OEM and are made by a company called MTE- THOMSON and where sorced from GSF.
Car drives fine with no apparant lose in power.
Any help as always greatly received.
B5 S4
S2tuner
Trader (Expired)
RE: Todays scan results
Post by S2tuner » Sat Aug 25, 2007 11:10 am
Always use original Bosch or Audi-supplied Bosch sensors on B5 S4s and you'll stay out of trouble ;) These codes are generally triggered by inferior quality aftermarket sensors...
HTH,
Mihnea
PS: your EGT sensor is definitely dead, get that changed ;)
Philws4
Post by Philws4 » Sat Aug 25, 2007 11:23 am
Cheers Mihnea for that i will contact GSF and see what they can do for me regarding replacing/reimbursing with OEM O2 sensors and get a new EGT ordered.
B5 S4
Philws4
Post by Philws4 » Sat Aug 25, 2007 3:14 pm
Had a result with GSF, they will credit me for the pair of sensors that i bought from them in May, and i have just ordered a new Bosch sensor from ECP which i should have by Wed/Thur this week. :thumbs:
Gonna put the new one on the N/S and have already put the 'old' original (Cause there was no fault code raised with this one back in May when the problem started) back in on the O/S. :roll:
Got to source a new EGT now, still at least it is the (G235) O/S that is knackered,so a POP to replace. :)
B5 S4
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 55 guests
