System Too Rich
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Jarv
System Too Rich
Post by Jarv » Fri Aug 24, 2007 7:51 pm
Hi guys,
The amber engine management light came on during my short drive home from work this evening. It seemed to come on immediately I gave it some beans around a tight bend, but that may be a coincidence.
When I got home I did a VAGCOM scan and got the following errors:
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
17537 - Fuel Trim; Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
Does this mean anything to anyone?
I cleared the codes and the engine management light on the instrument cluster went out. I haven't driven it since so not sure if it'll come back on again, I guess if there's a problem it will.
One more thing to add, I've heard about this limp mode that these cars go into. After the light came on I had a feeling that the car was slower, but that might have been in my head. How much slower is 'limp mode'? I mean, it seemed slower, but still faster than most, if that makes sense.
Any useful comments on the above would be welcomed.
Mike
Q7
Peakz
RE: System Too Rich
Post by Peakz » Fri Aug 24, 2007 8:23 pm
MAF or Lambda sensor perhaps?
Blue_Thunder
RE: System Too Rich
Post by Blue_Thunder » Fri Aug 24, 2007 9:02 pm
Isn't limp mode no boost? I've done quite a few miles with the N75 disconnected, and believe me, you'll know when there's no boost!
shineydave
RE: System Too Rich
Post by shineydave » Sat Aug 25, 2007 12:45 am
isn't fuel trim too rich a sign that the ecu is having to richen the mixture beyond the limit of it's available parameters. could be an indication of cheap low octane fuel, what do you put in it?
could also be an induction leak? sucking in air after the MAF perhaps
Dave
Jarv
Post by Jarv » Sat Aug 25, 2007 9:13 am
Thanks for all your replies guys.
Dave, I try and put V-Power in. The last tank was V-Power from Newport Pagnell Services, the one before that was whatever the super unleaded was at Tebay services near Penrith, and the one before that was Ultima IIRC. So, yes, because I've been away there's been a bit of a variety. In fact, just before I went away I put a full tank of V-Power in and a bottle of NOS Racing Octane Booster, which is supposed to raise the ron by around 8 (for Fighting Torque). The ECU could be doing the electronic eqivalent of asking me 'WTF is going on'?
I'll take the car out this morning and see if the light comes on again and give an update later.
Cheers.
Mike
Q7
Jarv
Post by Jarv » Sun Aug 26, 2007 8:51 pm
Taken the car out a couple of times yesterday and today, not far but enough to get the engine up to temp and give it a bit of stick, and no sign of the warning light coming on. Hopefully it was just down to the variety of octanes I've given it over the last few weeks.
Mike
Q7
yorkie
Post by yorkie » Sun Aug 26, 2007 11:38 pm
Could also be a boost leak.
Jarv
Post by Jarv » Mon Aug 27, 2007 1:23 pm
Cheers for the advice Yorkie, it's going to see Doug this week anyway, so I guess the health-check will throw up any issues such as boost leaks or MAF or EGT sensor failures.
Mike
Q7
yorkie
Post by yorkie » Mon Aug 27, 2007 5:43 pm
If its going to Doug its as good as mended. :D
Jarv
Post by Jarv » Mon Aug 27, 2007 6:17 pm
Yeah, my first set of suspicious engine related DTC's comes a week before a planned trip to MRC. What a stroke of luck :D .
Mike
Q7
yorkie
Post by yorkie » Mon Aug 27, 2007 8:43 pm
That man is a genius, he will fix your car I have no doubt about that. :D
derdle
Post by derdle » Wed Sep 05, 2007 7:14 am
Jarv,
Only just seen this post...so hopefully everything is OK now?
BTW you'll know when you are in "limp home mode", you put your foot down and the best part of bu**er all happens.
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
Jarv
Post by Jarv » Wed Sep 05, 2007 8:39 pm
derdle wrote:Jarv,
Paul
Hi Paul,
Yeah, everything is fine now. Engine management light hasn't come back on at all since I reset it.
Mike
Q7
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 22 guests
