Fecking Tyre Pressure Monitor!!
tombs
Post by tombs » Sat Aug 18, 2007 11:42 am
I think we may be able to get these for a better price, I'll check on Monday.
skiwi
Post by skiwi » Sat Aug 18, 2007 12:02 pm
Lig wrote:Hi Skiwi,
when you say new batteries, I assume you mean new 'rfid' tags as they appear to be a sealed unit?? And £100 a pop!!
Cheers,
Chris.
correct. rfid = radio frequency identification. at 100 quid someone is making some serious money....
BigMo
Post by BigMo » Sun Aug 19, 2007 4:27 am
hence why they're called "stealers"
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
GardinerG
Post by GardinerG » Sun Aug 19, 2007 7:57 am
What's funny is that we are effectively paying £80 a year for batteries! :shock:
4 sensors x £100 each) / 5 year life = £80 a year. Stealers indeed.
Tweaky
Post by Tweaky » Sun Aug 19, 2007 9:58 am
Mine is showing the very same symptoms at the moment....so maybe a bulk purchase could be arranged??
MY18 RS4 Carbon edition in Nardo
skiwi
Post by skiwi » Sun Aug 19, 2007 10:28 am
i take it you guys are off warranty or the warranty doesn't cover?
suggest trying a purchase from the us of a.
the unit is not unique to the rs6, it is shared with other a6's, the allroad and the d2 & d3 a8's. however the rfid frequencies will need care - there are 2 frequencies used, and if you use the wrong one you will have 2 issues:
1) you will need to replace the aerial as well, and
2) you will need to be careful of interference on your rf spectrum. at the power levels of these puppies it won't bother the authorities but could bother your cell-phone or sat-nav....
to ascertain your "type" look at your vehicle sticker. you should have either "5d1" or "5d2" on your sticker. relevant part numbers are:
"5d1": 4d0907275
"5d2": 4d0907275a
Lig
Post by Lig » Mon Aug 20, 2007 12:09 pm
Cheers for all your help Skiwi,
Mine is the 5D1 - I assume this also relates to the key fob transmitter frequency???
I will have the system connected to VAG COM and hopefully this will show which one(s) or what is dodgy.
Will let you know.
Cheers,
Lig.
skiwi
Post by skiwi » Mon Aug 20, 2007 7:41 pm
let me know how you get on..
s4woody
Post by s4woody » Mon Aug 20, 2007 8:09 pm
as far as im aware the "A" at the end of the part number is for australia and new zeland models also..
that could also be arranged..
GARTH ROAD MOT CENTRE LTD
020 83353032
tombs
Post by tombs » Tue Aug 21, 2007 1:48 pm
KIS Auto parts can supply these for £80.00 inc VAT. If your interested drop me or S4woody a pm,
GardinerG
Post by GardinerG » Tue Aug 21, 2007 2:11 pm
£80 for a battery, :lol: Sorry Tom, I just see the funny side! It's a good price compared to Audi tho. I'll probably be needing a couple so will let you know when I've had a chance to check.
G
tombs
Post by tombs » Tue Aug 21, 2007 2:23 pm
Oi...i know what you mean though,they arent cheap in the first place to buy in.
GardinerG
Under Pressure?
Post by GardinerG » Wed Aug 22, 2007 7:48 pm
Oki doki, I think I'm going to need 3 valves and 2 sensors as I have 1 brand spanking new wheel in need of both, 1 leaky valve (I think) and the following error:
Address 65: Tire Pressure
Control Module Part Number: 4D0 907 273 C
Component and/or Version: Reifendruckueberw. D310
Software Coding: 22350
Work Shop Code: WSC 00000
1 Fault Found:
01468 - Front Right Tire Pressure Sensor (G223)
53-10 - Supply Voltage Too Low - Intermittent
What I don't get is that it is shown as having 32 months life left using VAG-COM!?! WTF? Anyone else have any ideas what could be causing this?
Tom, I think the part numbers are 4D0907275 for the sensor (as above), and 4D0601361 for the metal valve. Oh and I *think* 4D0601361 comes with both the insert and the cap (N90873301 & N90872901)
Grant
P.s. The approximate life of these units is 7 years (according to ELSA).
skiwi
RE: Under Pressure?
Post by skiwi » Wed Aug 22, 2007 7:57 pm
yes, i've heard that same ting about the confusing "battery life" message. i assume that the software is reflecting a signal strength as an approximation of the battery voltage - i dont know how the voltage could be read indirectly - probably flakey in other words...
bottom line is that the battery is in the tag so that low voltage can only mean 1 thing - replace the tag....
Rich_C
Post by Rich_C » Wed Sep 12, 2007 7:08 pm
Well I've had the car back from the dealership for a week now and my TPM woes are behind me. Symptoms exactly the same as described by Grant above - fault saying the sensor voltage on 3 out of the 4 was too low but when checked each sensor was showing 28 months left. After a few attempts to get the TPM to rebond with the sensors without joy the dealership swapped out all 4 sensors and voila the warning hasn't appeared since.
Rich.
The Present ...
C7 RS6 Avant - Estoril Blue - everything bar B&O - Akrapovic only upgrade (... so far)
The Past ...
C6 RS6 Saloon - Phantom Black - lots of factory extras but no tuning.
C5 RS6 Saloon - Daytona with black Interior - Full Milltek with 100 cpsi cats - AMD Remap - Bilstein PSS9 Coilovers - MTM Bimoto's - Phaeton Brake Upgrade - RNS-E + Bluetooth + Multi-media player + Phatbox
911 (996) Turbo - X50 - Aerokit - PCCB
Users browsing this forum: Majestic-12 [Bot] and 272 guests
