From the Main Menu :-W8PMC wrote: What screen/function do you access the ECU Flash information??
Select Control Module --> 01 - Engine --> Advanced ID
Cheers Clive. I'll get Awesome GTI to check this out this afternoon assuming they have VAGCOM & report back on the findings tonight.CliveH wrote:From the Main Menu :-W8PMC wrote: What screen/function do you access the ECU Flash information??
I just did!W8PMC wrote: Failing that, could someone with a re-mapped RS4 & VAGCOM check out what theirs says??
Would not go as far as to say that Varsity, not least if you drive the car or rev it to the red somone could tell instantlyVARSITY wrote:So far then we know for sure that a re-map via the ecu removal isn't detectable?
No, its not flashed with the ECU remomal its coded in "background de-bugging mode" or BDM completely different to 'flashing'W8PMC wrote: Curious to know if VAGCOM shows OBD flashes & how if this is the case an ECU out re-map is not shown, as surely the ECU flash is exactly the same regardless of the route?? One is simpler going via the diag port, but both routes actually flash the ECU.
Sure am, booked in at Awesome GTI for 2PM.SimonH wrote:Paul, are you having your exhaust fitted today.Sorry for the off topic question fellas.If you are, lets have the full report afterwards, regards, SIMON.
Dont tell us how good it is,W8PMC wrote: Sure am, booked in at Awesome GTI for 2PM.
Will post a report tonight.
Simon, seperate thread has just been posted.SimonH wrote:So Paul,
Come on then, tell us, tell us!!!!![]()
Simon.
Users browsing this forum: Bing [Bot] and 159 guests
