Has anyone changed these on the RS6?
My outside front cv boot is split and I have purchased a replacement. I had a quick look today and not sure of the right way to get at the drive shaft and if I need any special ball joint separator tools?
Tips on replacing o/s front cv boot
RE: Tips on replacing o/s front cv boot
pm sent .
Unit 20
0151 3366888
0151 3366888
thanks Grizz - you've saved the day (again!)
generally whould have to be replaced. a ripped boot is pretty common and replacing the boot and repacking with grease is all that is required. generally the cv shouldn't be replaced unless it is noisy,,,
Re: RE: Tips on replacing o/s front cv boot
Hence the title 'Tips on replacing o/s front cv boot'skiwi wrote:generally whould have to be replaced. a ripped boot is pretty common and replacing the boot and repacking with grease is all that is required. generally the cv shouldn't be replaced unless it is noisy,,,
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
RE: Re: RE: Tips on replacing o/s front cv boot
marmite, you are clearly a very attentive person if a little irony challenged - either that you are one of life's natural policemen....
but you did make me re-read the original request.....
tips:
1) you can get away with re-using the (old) axle bolt to remove the cv from the axle, it will tighten down and pull the joint off, but if no luck with that method, a 2-arm puller will do in place of the special tool...
2) don't displace the balls, and make sure to clean all the old grease out. use a citrus solvent and rinse with water and thoroughly dry.
3) don't be afraid to us a bfh to get it all back on the shaft - albeit with a wooden buffer....
4) instead of the proper circlip pliers you can use a pair of straight cutters.
5) don't circlip the small end until you have re-assembled to allow time to get the air out of the boot...
tips:
Users browsing this forum: No registered users and 148 guests
