low power !
hi 42tt , the 453 was at the estimated crank hp . I did see a dyno plot for a b5 rs4 that had 360 whp but had 440 crank . mine was 362whp.
I'm getting it back on the r/road tomorrow.
Unit 20
0151 3366888
0151 3366888
3rd gear .
Unit 20
0151 3366888
0151 3366888
E = energy
P = Power
P = energy / time
E = 1/2 m v ^2
v = velocity
m = mass
So the kinetic energy of a car car of mass 1860KG moving at 100kph (27.78 metres per second) is:
0.5 * 1860 * 27.78 * 27.78 = 717.6k joules.
If this takes 4.7 seconds the power input is 717.6k/4.7 = 152kW = 204BHP.
Which makes perfect sense.
P = Power
P = energy / time
E = 1/2 m v ^2
v = velocity
m = mass
That's how devices like my G-Tech work BUT you need a perfectly flat road, you need to attain perfect traction, you need to accurately know the weight of the car, it needs not to be windy (or you need to average passes in the opposite direction). All in all it's easier to use a dyno IMO.
Also it's a total work done - you don't get any data on the changes through the rev range.
Fen
'03 RS6 Avant in ebony black/grey leather, black optics, solar roof, dippy & foldy mirrors, RNS-E, Bluetooth, West Tuned SOLD
correct for steady state, not acceleration....Rupert wrote:E = energy
P = Power
P = energy / time
E = 1/2 m v ^2
v = velocity
m = mass
Which makes perfect sense.![]()
we need the work done to get the 1850kg missle to 100kph in 4.7 seconds...
Grizz,
My car was also dynoed in 3rd gear on a Dyno Dynamics Dyno. As i am unsure of your modifications i cannot comment on your power output, having said that the only true test is if the dyno is in "Shoot Out Mode" which corrects HP for temp etc and that your car was dynoed on the same dyno for a base line HP figure before modifications.
My dyno specs are:
Ambient Temp 26 Celcius
Intake Temp 28 Celcius
Gear 3rd
343.2 WHP
A better measure of HP is at the 1/4mile where you can see from your trap speed my car has run a best ET of 13.07@106MPH on a not so cold night.
Regards,
42tt
My dyno specs are:
Gear 3rd
343.2 WHP
Regards,
42tt
Well it's a bit better , it made 390 whp , i'll look at the temps later . it was in "shoot out mode"
Unit 20
0151 3366888
0151 3366888
Actually part of the idea of Dyno Dynamics shoot-out mode is that you can't play with the settings to inflate the readings, the other being that it adjusts for ambient conditions to try to make readings on different days comparable.skiwi wrote:you could just tell them to change a few of the parameters to ensure the final numbers were over 400?
Fen
Users browsing this forum: Google [Bot] and 160 guests
