As far I know it has never been confirmed / unconfirmed that all Recaros are heated but has been discussed many many times.
Parts from broken 2000 S4 B5 avant
QuantumJohn
QuantumJohn
The following items are now sold:
Front fog lights
Spare set of front bumper plastic grills
Clocks/Dials
Set of genuine mats in dark grey/black
All four abs sensors
I also have the follwing items for sale:
Front wiper motor and wiper mechanism
Front wiper arms
Battery tray (just incase those of you that have had it sitting in water for a while find it rusted)
Air con canister
Air con bulkhead pipes
Thanks,
John
Front fog lights
Clocks/Dials
Front wiper arms
Air con canister
Thanks,
John
QuantumJohn
Here is a revised list now that a number of bits have been sold and I have found a few more!
All four doors including glass, window motors, locks, catches.
Pair of front wings
Rear near side wing – brand new
RS4 tailgate including glass, wiring and spoiler
Rear side windows for avant from RS4 with TV ariels
Black avant roof rails including bolts
Clear rear lights – not lexus style but In Pro TUV approved audi style
Door seals
Door hinges
Door striker catches
Dash including passenger airbag
Bulkhead sound deadening
Metal dash support beam
Glovebox
Lower drivers side dash panel
Wiper switch including DIS switches
Top half of steering column including ignition switch
Complete gear lever mechanism – ideal for those wishing to do the home made short shifter mod as described by shineydave.
Heater box including heater matrix
Floor heater tubing
Head lining for non sunroof car - black
Grab handles
Pedal box including brake and clutch pedals
Throttle pedal including position sensor
Brake servo
Wiring loom including fuse box
Brake fluid level sensor + lots of other sensors that I have probably forgotten about
Brake pedal switch
Fuel gauge sender
Fuel pump
Airbox bottom
Airbox top including all sensors
Gear knob
Boot carpet
Boot load cover
Sunvisiors – black, facelift type
Central sunvisor
Rear view mirror
A pillar interior trims – black
B pillar upper trims including alarm sensors
Kick panel plastic trims
Plastic interior sill cover near side
Upper plastic trim around inside of tailgate
All seat belts including mounting bolts
Central locking pump
High level brake light
Spare wheel kit – polystyrene centre and plastic cover with jack and wheel brace (never used by the looks of it)
Off side front suspension hub and carrier including bearing
Both rear suspension hubs and carriers including bearings
Rear suspension arms
Rear diff mount
Front subframe
Rear subframe
Petrol tank
Rear drive shafts
Washer bottle including all pumps
RS4 radiator – brand new
ECU box top and bottom including nuts and foam seal to bulkhead
Off side intercooler and hoses
All solid brake pipes
Solid fuel pipes
Front wiper arms
Air con canister
ABS pump
Plus a whole host of nuts, bolts and wiring clips.
I also have:
Airbag controller - 8D0 959 655J
Combi-sensor for acceleration and yaw - 4B0 907 637A
ESP controller - 8D0 907 389E
Alarm Motion Control Sensor - 4B0 951 173
and decided to sell:
Complete polished alloy door mirrors
Complete set of brushed ally window surrounds off an RS4, perfect condition
Cheers,
John
Pair of front wings
Door seals
Door hinges
Glovebox
Floor heater tubing
Grab handles
Brake servo
Brake pedal switch
Fuel gauge sender
Fuel pump
Airbox bottom
Gear knob
Boot carpet
Boot load cover
Central sunvisor
Rear view mirror
Rear diff mount
Front subframe
Rear subframe
Petrol tank
Rear drive shafts
Solid fuel pipes
Front wiper arms
Air con canister
ABS pump
I also have:
Cheers,
John
Dan_Gliballs
QuantumJohn
Here is a revised list now that a few more bits have been sold. Remeber all bits from an 18K mile car.
Pair of front wings
Door seals
Door hinges
Rear bumper - new and painted
Glovebox
Complete gear lever mechanism (ideal for those wishing to do the home made short shifter mod as described by shineydave)
Floor heater tubing
Grab handles
Brake servo
Rear half of wiring loom
Brake pedal switch
Fuel pump
Boot carpet
Central sunvisor
Rear view mirror
Rear diff mount
Front subframe
Rear subframe
Petrol tank
Rear drive shafts
Air con radiator
Solid fuel pipes
Front wiper arms
Air con canister
ABS pump
Pair of front wings
Door seals
Door hinges
Glovebox
Floor heater tubing
Grab handles
Brake servo
Brake pedal switch
Fuel pump
Boot carpet
Central sunvisor
Rear view mirror
Rear diff mount
Front subframe
Rear subframe
Petrol tank
Rear drive shafts
Air con radiator
Solid fuel pipes
Front wiper arms
Air con canister
ABS pump
still got the ecu
have you still got the engine ecu?
if so, what is the part number?
how much would it cost?
cheers,
glyn
cheers,
glyn
QuantumJohn
Users browsing this forum: Google Adsense [Bot] and 23 guests
