Clutch Pedal Switch (F36)
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
neily
Post by neily » Mon Aug 06, 2007 7:17 pm
Ok Guys...
Just done my weekly VAGCOM check and got this error message from the Engine module....
Can anyone translate this into (basic) English please ? (I have not noticed any issues with the clutch or gearbox..)
1 Fault Found:
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
Readiness: 0000 0000
Cheers :beerchug:
2001 RS4 Avant - thats been touched by the MRC magic wand.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008
GrahamS4
RE: Clutch Pedal Switch (F36)
Post by GrahamS4 » Mon Aug 06, 2007 7:29 pm
You do a weekly vagcom check?!!
I figure clutch pedal switch failed. Not uncommon on VAG cars I believe. Only a few pounds to replace. Unless you have cruise I doubt it has any relevence.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
neily
Post by neily » Mon Aug 06, 2007 8:04 pm
yeah Graham - just call me Mr Paranoid.........
I do have cruise but haven't tried this recently. Does this mean that cruise is currently fooked until I replace the switch ??
GrahamS4
Post by GrahamS4 » Tue Aug 07, 2007 7:18 am
Don't know to be honest. I am actualy working from information I got from APS when they retro fitted cruise to our MKIV Golf. The clutch switch had an intermittent fault which they advised me of. They didn't seem too concerned and said it was very common hence they stocked them. I asked to be changed anyway as it was literally a few quid only and minutes to fit.
I assume cruise either fails or doesn't work 100% as I note on VAG cars cruise disengages when you dip the clutch.
neily
Post by neily » Tue Aug 07, 2007 7:27 am
ok thanks Graham. I'll give 'crusie' a try later this morning when I'm out and about....
Return to “DTC / VCDS”
