Can anyone tell me about my car with these readings ??
RE: Can anyone tell me about my car with these readings ??
Adam:
Well, you didn't actually get up to 6,500 to calculate a FATs time, but it did take just over 10 secs to go from 4,240 to 6,400 which is far too long.
Your peak MAF reading of 192 is also rather low.
Your actual boost is well below specified all the way up.
I'd hazard a guess at you having a boost leak somewhere is the system.
I'm also puzzled by the specified boost as it seems a bit low for a (presumably) stock map
Clive
Thanks Clive.... all explains here as to why thats all low....
http://www.rs246.com/index.php?name=PNp ... 85c290c136
ah OK Adam - isn't that the sane set of data??
Clive
Yeah, same data cause i posted this post 1st...... then i noticed something was wrong with the boost so i posted again in to give some people some ideas
ok Adam. thread closed then?
I see a split TBB was the problem.
Clive
Users browsing this forum: No registered users and 31 guests
