B5 S4: "How to..."
REPAIRING ABS MODULE
There appears to be a common failure mode in the electronic part which can cause the ABS warning to come on intermittently. Thanks to UKS4APR1, the following link shows clearly how this can be repaired.
http://passat-b5.ru/index.php?option=co ... &Itemid=57
Here's the original thread:
http://www.rs246.com/index.php?name=PNp ... ic&t=62805
2001 Silver S4 Avant
Blue_Thunder
- Top Gear
REMOVING FRONT SEATS
An excellent write-up here worthy of a spot on the Sticky!
http://www.rs246.com/index.php?name=PNp ... ic&t=55647
Painting (or just replacing) corroded rear door trim pieces
by shineydave
http://rs246.com/index.php?name=PNphpBB ... 396#218396
by shineydave
Mark
Blue_Thunder
- Top Gear
VAG-COM Adaptation Codes
Been looking for something like this for a while. Useful if you want to auto-lock the doors, open/close all windows with keyfob, change idle speed, Interior Alarm sensor sensitivity, etc.
http://ross-tech.com/vag-com/cars/audiB5.html#35
Users browsing this forum: No registered users and 20 guests
