I got the RS6 callipers and decided to go for the B7 RS4 drilled disks (instead of RS6 disks). I have been using the OEM black pagid pads and on my 3rd set now (probably disks have covered 6k ish now)
As you can see there are some big cracks appearing... now, I have been very happy with these disks, they have done the job, never had any fade or warping etc, but obviously the cracks at 6k is annoying...
I wonder if these have appeared because of one of the following.
I did not clean out the holes and they filled up with brake dust, it was packed in tightly, I had to drill it out.
So,
1) Brake dust expands quicker than the disks, so can create undue stress and cracks?
2) In drilling them out I have caused stress/stripped the side of the holes and caused premature cracking?
3) The heat build up with my usage was just too much and over 6k it has cracked?
Main reason for asking this, if it’s because of 1 or 2 I will go ahead and buy the B7 disks again, if its because of 3, I will probably try the RS6 disks this time around...
More Pics here
