So, i'm planning on taking the S3 to the continent for a week - and looking in the manual it says the headlights can only be changed at an Audi garage, which is a PITA...
I can't imagine its that difficult - so does anyone know how you switch it over?
I'm guessing because they are HID you can't simply stick on the deflectors?
Changing Headlights for the Continent
RE: Changing Headlights for the Continent
Inside the headlight unit there is a small lever just below the projector unit. If you flick that upwards a shutter moves over part of the beam to make it flat.
It is a little fiddly though. It's probably easier to take the headlight out to do it.
Here's a picture of the lever on a facelift S3 headlight.
HTH
HTH
- Attachments
- Headlight shutter lever.jpg (67.31 KiB) Viewed 1174 times
