Engine stuttering...
Hi Fellas,
Need your opinion...
The last couple of times i've driven the car and have been a little spirited, upon lifting off the accelerator the car stutters (feels like the engine wants to jump out) even though I have a DTS fitted.
Only happens when I boot it and then lift off quickly. The temp today was 15c so i do not think it is down to the air temp....any ideas what could be the cause ?
Jem
Jem
RE: Engine stuttering...
Sparkplugs, might be worth changing them if you haven't done them in a while.
Or it could be fuel related like the filter on its way out or your injectors.
SKN remap, K&N Filter, Miltek CatBack Twin Jet-
BHP under Construction!!!!
Vag com your car and see what comes up. That really your first move.
Un-educated guess I'm afraid as I'm a bit of a mechanical-<beep>, but I'm pretty sure that if you lift off the throttle and the engine keeps going for a sec, then it's a sign of a diverter valve fault.
I'm ready to be corrected though and willing to learn, so shoot me down if needsbe
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
Hmmmmm, didn't think of that one. You're a more sound mechanic than me Ads4.
Mine does this when letting offer accellerator in low gears, blame it on the clutch. However I did change the fuel filter and it helped it alot in 1st/2nd.
I have a pack of spark plugs here as well, will try them.
V10 5.0 Phaeton now and 2.7T Allroad
- ChipHazzard
Ok the out come of this is a boost leak caused by a split in the TBB for those that are interested
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
Users browsing this forum: Majestic-12 [Bot] and 78 guests
