Double DIN sat nav fit
dazzer
Post by dazzer » Mon Jun 18, 2007 12:06 am
Hi all,
I have a Nav plus retro fit in the pipeline. I know I need the double din cradle and different climate control unit but do I need a new centre console also please?
Dazzer
TDiAvant
RE: Double DIN sat nav fit
Post by TDiAvant » Mon Jun 18, 2007 10:44 am
I'm not sure what year or model car you have, so I'm going on a B6/B7 model.
Double din cage part number is
8E0 858 005 F
Climate control unit
Well you can cut the sides of your unit, of buy the double din version New from Audi your looking at £400
But I would need to know year, make and model and does your car have heated seats .
I do have some double din climate control units in stock.
Center Console
Well again that can be cut to fit the double din cage.
Below is a picture of a single to double din conversion I've done, were the climate control unit and the center console has been cut to fit the double din.
dazzer
Post by dazzer » Mon Jun 18, 2007 11:41 am
Cheers - it's a 99fl B5.
TDiAvant
Post by TDiAvant » Mon Jun 18, 2007 12:08 pm
I'm just about to start a B5 double din converson, I should have some more information tomorrow.
dazzer
Post by dazzer » Mon Jun 18, 2007 12:57 pm
Look forward to hearing your experiences :thumbs:
JDB
Post by JDB » Thu Jun 21, 2007 4:30 pm
I have 2000 B5 S4 facelift with heated seats and want to upgrade from a Concert single DIN headunit. Where can the parts be sourced from?? I would like to buy air con unit? TDIAvant where are you based?
TDiAvant
Post by TDiAvant » Thu Jun 21, 2007 10:02 pm
Well I was let down on the double din cage, so my conversion is on hold unit I can find a used one, as the price on a double din cage of the B5 is just short of £200. I'm based in the north east.
JDB
Post by JDB » Fri Jun 22, 2007 9:29 am
TDIAvant just to confirm the parts that are needed:
1) Double DIN cage
2) Air con unit controller with heated seats (is the temp sensor built into this as well?)
3)Sat Nav plus system and cables
Anything else
ajsl
Post by ajsl » Fri Jun 22, 2007 9:32 am
I was interested in this for a while but the sheer cost of the double DIN cage + new air con unit on top of the new sat nav unit makes this a very expensive proposition. :(
I seem to recall the air con units are around £400 ish?
PetrolDave
Post by PetrolDave » Fri Jun 22, 2007 12:33 pm
ajsl wrote:I seem to recall the air con units are around £400 ish?
The cost and the sheer complexity of the part numbers for the air con units mean that a lot of people who have done the single-to-double DIN conversion just trimmed down their existing air con unit.
Cardboard template and a miniature plane plus a file seems to be the favoured combination.
Dippy
Post by Dippy » Fri Jun 22, 2007 12:38 pm
I was lucky as I already had the double-DIN cage. However I went for the full monty (TMC, TV, LCD screens, AV interface) so I needed a lot of kit. I tried to get as much as possible on www.ebay.de, but I still needed some new parts (such as the diversity switcher and the UHF antennae). In all it ended up costing me over a grand (and I did get my TMC and SatNav+ units quite cheap!). If I had known that at the start (plus the fact that it would take me nearly a year to get all the parts), I don't think I would have bothered. You have got to really want one!
ajsl - are you looking for parts on www.ebay.de?
2001 Silver S4 Avant
JDB
Post by JDB » Fri Jun 22, 2007 12:46 pm
Thanks for the advice not quite sure 1000 notes is worth!!
ajsl
Post by ajsl » Fri Jun 22, 2007 12:53 pm
Dippy, no I wasn't. But overall I think the cost/hassle if you have a single DIN unit initially are too high - unless as you said you really want it! :)
dazzer
Post by dazzer » Fri Jun 22, 2007 6:14 pm
Starting to think the cost outweighs the benefit myself. What the heck is a Diversity Switch please :?:
PetrolDave
Post by PetrolDave » Fri Jun 22, 2007 6:19 pm
There are 3 or 4 antennas (mostly in the glass) of most Audis and the radios have 2 antenna inputs - the diversity switcher switches the "best" antenna through to the tuner so you get the best possible radio reception.
Return to “Electrical”
Users browsing this forum: No registered users and 98 guests
