I have just purchased first RS2, having looked for one on and off for a few years. I am used to the "big reds" as I have a Porsche 964 with them fitted. I also am aware that they can "stick" if left unused or whatever, but I've had no issue with that so far. However, on the RS2 the rear OS calliper is binding (squeaking at low speed) - could it be the handbrake inside the hub, as it is worse when I put on the handbrake a bit and the same noise is then heard in the ns brake disc? Then today, every time I hit the brakes a loud rubbing/vibrating noise was felt just at point of brake and then it went away. What I did notice was that the rubbing/vibrating was also evident whilst driving at normal speeds and was heard in the background.
The car has 77k on clock and has had FSH up until March of this year, so I was surprised when this happened.
Any advice on how to sort this? Also (and I've traced a thread regarding upgrades) any advice on making the brakes have more power - although the callipers are supposed to be really good, the brakes have got a soggy, spongey feel to them. They don't give positive, full on stopping sensation. Would EBC green stuff pads help? Are the callipers really up to the job - I would have thought they should be as they work twice as good on a Porsche 944 or 964.
Would appreciate any good constructive advice as the RS2 is one of my dream cars and this issue just spoils things a bit.
RS2 sticking brake callipers
RE: RS2 sticking brake callipers
You will need a refurb of the caliper. Its the years not the miles.
The steel backing plate and alloy caliper lead to galvinisation build up which stops full retraction of the cailper. You need to strip down remove old backing plate remove galvinisation buid up and replace with new backing plate OR replace with OEM ~ £250 a side IIRC.
Forget EBC altough not a great issue on back. Stick with OEM (textar)
BTDT !!
BTDT !!
RS2 'an estate car named Desire'
just refurbed my rear rs2 calipers , new plates, pads plus hand brake shoes, the plates were reasonable at 60 quid@ for the rears , audi dealer, thought i would try that first before new calipers ,it work a treat,
nb going to try ebc on the rears?
- Corey
Re: RE: RS2 sticking brake callipers
Wouldn't recommend itrsmotors wrote: nb going to try ebc on the rears?
Corey
