Another TV AUX Question.....
neily
Post by neily » Thu Jun 21, 2007 12:51 pm
Hi all - apologies if this has already been covered off in another thread...
I have just bought a 2001 B5 RS4 Avant with the OEM TV Tuner and CD Based SATNav+ system. Looking to add a couple of mods to keep the nippers quiet in the back....
1) make 'TV in motion' function - I understand this is just a case of disconnecting the GA white/blue lead from the headunit ??
2) As I understand it, as I have the non-B TV Tuner it should be able to use the AUX inputs for hooking up an external DVD Player (will also allow DVD's to be playe din the front once TV in motion has been resolved...
3) Am I able to create an additional OUTPUT for the OEM TV Tuner as I want to hook up additional screens in the backof the headreasts with the ability to view TV ??
Any help is GREATLY appreciated.....
shineydave
RE: Another TV AUX Question.....
Post by shineydave » Thu Jun 21, 2007 3:19 pm
tv in motion is just a matter of snipping the GALA wire as you say, i've put a small pushbutton switch in the line so i can enable or disable it as required.
you can plug any video or audio source into the tuner and listen or watch by pressing the mode button when in TV to switch to the aux input and yes, it works whilst on the move too assuming you've cut the GALA wire
not sure about the third question, i think the answer is no but no doubt someone will be along soon who knows the definitive answe
Dave
Dippy
Post by Dippy » Fri Jun 22, 2007 12:48 pm
2001 Silver S4 Avant
neily
Post by neily » Fri Jun 22, 2007 1:28 pm
Nice one Dippy !!! - answers my (many) questions in 1 easy swoop !!
theaxe
Post by theaxe » Fri Jun 22, 2007 1:42 pm
Note that snipping with GALA wire will greatly reduce the accuracy of the satnav so a switch as ShinyDave suggested would be a good idea.
Phantom Black '06 RS4 Saloon
Recaros, loaded (except ceramics & bluetooth).
craigyb
Post by craigyb » Fri Jun 22, 2007 2:01 pm
Actually on the RNS-D, that gala wire is only used for the speed sensitive volume and can be cut without affecting the navigation, as the RNS-D has two feeds.
This is a problem with the RNS-E in an A6 etc as it has only one feed.
shineydave
Post by shineydave » Sat Jun 23, 2007 8:23 pm
thought mine still kept pace with the location of the car ok, i couldn't see any difference with the button on or off. i only fitted a switch in case of a tug by plod when the TV was on
Dave
Dippy
Post by Dippy » Mon Jun 25, 2007 1:09 pm
I have a switch because I like having speed-sensitive volume control!
IIRC the issue is that the RNS-D was fitted to a range of models, and there are SOME cars which do have a nav problem when the gala connection is removed.
Another reason to fit a switch is in case of an accident and the investigator discovered that the gala wire was permanently disconnected, and we all know how insurance companies never try to avoid paying up do they?
neily
Post by neily » Mon Jun 25, 2007 2:44 pm
Ok guys, I'm REALLY struggling getting the SATNAV+ HU out.... :oops:
Looks like the top right clip is not dis-engaging....
Is it possible to get to the back of the HU be removing the whole centre console, or at least attacking the side of the console ??
Any help is really appreciated....
Dippy
Post by Dippy » Tue Jun 26, 2007 12:24 pm
No, I don't think you can. I had difficulty removing my HU. There is a certain technique you need with the keys and so I'd just recommend that you persevere.
lengster1
Post by lengster1 » Tue Jun 26, 2007 12:50 pm
Try easing a bank card round the edges coated in vasaline or similar,it will help break the seal and assist it popping out,makes a change from vasaline assisting popping things in ha ha,try popping one side at a time rather than getting both sides ot the same time,patience is a must those little keys scratch the unit easily as my main agent proved !!!!!!!
neily
Post by neily » Tue Jun 26, 2007 1:01 pm
Ok thanks. I will get my flexible friend out tonight with the large tub of vasaline.....
BTW - i have no idea what you're talking about re another use of vasaline ?!?! :oops:
Return to “Electrical”
Users browsing this forum: No registered users and 23 guests
