EGT fault help needed
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
TWH
Post by TWH » Tue Jun 19, 2007 9:04 am
Hi,
Logged a fault the other day on one of the EGT sensors, hopefully someone can tell me which EGT this relates to - there's one for sale in the classifieds but I have no idea if it's the one I need:
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-10 - - - Intermittent
Cheers in advance for any help :)
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten :(
confusionhunter
RE: EGT fault help needed
Post by confusionhunter » Tue Jun 19, 2007 9:12 am
You could try disconnect one and see if it removed the intermittant of bring up another fault that should tell you which one. Make sure you get an EGT with exactly that same part number. I had to get mine the same as my car had been remapped and there are slight differences apparently. Mine ended in "D".
Mark.
shineydave
Post by shineydave » Tue Jun 19, 2007 7:28 pm
if you check in the self study guide you see that G235 is the right hand side one and G236 the left hand as you sit in the car
C9CRM
Post by C9CRM » Tue Jun 19, 2007 7:56 pm
Hi
I have been under my bonnet tonight working out the same fault code and have found that lucky for me the
" 17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent "
message corresponds to the egt on the drivers side of the car and is by far the easier one of the two to get to!!!
now to sort out the rest of my faults!!!!!
Address 01: Engine
Part No: 8D0 907 551 C
Component: 2.7l V6/5VT 0002
Coding: 05611
Shop #: WSC 00337
5 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Audi S4 B5 2.7 V6 TT quattro 1998 Silver
Suzuki GSXR750 1999 Blue/White
yorkie
Post by yorkie » Tue Jun 19, 2007 8:47 pm
I think if you change your maf you may find the lamda and egt codes will go unless the damage is already done.
TWH
Post by TWH » Wed Jun 20, 2007 12:12 pm
Mine's an E rather than G (which I guess is the later ones). Cheers for the help guys!
mattykerby01
Post by mattykerby01 » Wed Jul 18, 2007 1:17 pm
Did you get this sorted?
Had the same code on my RS4 B5 last week, but on sensor 2 (Passenger side) - changed EGT this weekend (what a bitch), now all ok.....
Philws4
Post by Philws4 » Sat Aug 25, 2007 3:04 pm
mattykerby01 wrote:Did you get this sorted?
Did you need any special tools to do this as it does(as you suggest) look like a PITA of a job to do?
B5 S4
GardinerG
Post by GardinerG » Sat Aug 25, 2007 4:33 pm
lol, I rember doing this on the 2.7T A6, ended up stripping some of the nearby hoses and with a spanner attached to a piece of string so I didn't lose it down the back of the engine. Oh, and I needed some new skin on my knuckles too. It's amusing to compare it to how easy the driver's side is to replace!
soapy_g
Post by soapy_g » Mon Oct 08, 2007 5:29 pm
Is it possible to avoid taking the engine out to replace the passenger side EGT sensor ?
yorkie
Post by yorkie » Mon Oct 08, 2007 9:02 pm
Yes but I believe it is a bit fiddly.
Philws4
Post by Philws4 » Wed Oct 10, 2007 10:39 pm
Check this out for a bit more info :)
http://www.audiworld.com/tech/eng73.shtml
B5 S4
Return to “DTC / VCDS”
Users browsing this forum: Google [Bot] and 31 guests
