I am off to see another allroad soon. I took my audi technician mate along who had his special VAS laptop to check all the fault codes.
I am off to see another car, but it's too far for him to travel. I've just bought a copy of vagcom, can I run a full fault diagnosis scan like you can on vas?
The vas brought up things like an intermitidant deadlock failure, as well as potentiometer failure on one of the aircon flaps. the kinda thing no-one would be able to check otherwise! Will vagcom do the same easily?
thanks!
mark
buying a new car, vagcom any good?
m6rk-allroad
- shineydave
RE: buying a new car, vagcom any good?
i would expect any faults that are logged by VAS to be logged by vag-com as long as the dongle is compatable with the car being tested
Sebastian
Dave is right, the codes the VAS shows will also be shown by VAG-COM (easiest way is to run an Auto-Scan). In some cases it makes sense to do some logging (e.g. MAF or boost related) on the test drive with the car to find hidden issues.
Sebastian @ Ross-Tech.com
m6rk-allroad
what sort of things would indicate a problem on the maf and boost settings? any errors i should be looking out for in particular?
2000 Audi Allroad with a new nice RS6 additions
2004 Audi S4 4.2 v8 (poorly)
Sebastian
What car exactly are you looking at? What engine?
Users browsing this forum: No registered users and 22 guests
