RS 4 at full chat....?
2.7 V6 30v biturbo - 380 bhp
Matt1
Post by Matt1 » Mon May 21, 2007 9:27 pm
If for argument's sake one was able to experience an unmodified (but very clean), 01 reg, 51,000 miler RS4 at full chat on a nice straight, unimpeded road, on a virtually windless day, should one be dissapointed with less than enthusiastic progress from 130 - 140, and then not getting any further than 140mph?
Was under the impression that the limiter cut in at 155mph?
Any thoughts?
Nige_RS4
RE: RS 4 at full chat....?
Post by Nige_RS4 » Mon May 21, 2007 9:57 pm
In a word, YES! Unless it was it stuck in 4th gear?
Try changing the MAF (verify this using vag-com)!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
simple1
Post by simple1 » Tue May 22, 2007 7:35 am
Should pull the limiter without any trouble at all, which in the case of my car is indicated 170 on the speedo..
Hiltoa
Re: RS 4 at full chat....?
Post by Hiltoa » Tue Jun 05, 2007 12:19 pm
Matt1 wrote:...at full chat on a nice straight, unimpeded road, on a virtually windless day, should one be dissapointed with less than enthusiastic progress from 130 - 140, and then not getting any further than 140mph?...
...Any thoughts?
I'd definately be disappointed, because my slightly modified (not very clean) 00 reg, 88,000 miler, 1.8T A4 (180bhp ish) would be sat on your tail, if not slowly creeping past you!
I sense great joy to be had if you (for argument's sake) fix the problem and discover what an RS4 really can do... :wink:
JustinM
RE: Re: RS 4 at full chat....?
Post by JustinM » Tue Jun 05, 2007 10:26 pm
With no mods and no change to the limiter you should pull around 165mph (GPS measured). I know, I have done it (not in the UK)
GardinerG
Post by GardinerG » Tue Jun 05, 2007 11:22 pm
140 limit in an RS4? No. As Nige says, check your MAF and check for any errors. I've had many ECU errors over the years, but none have caused the check engine light. Also check your hoses/diverter valves for leaks leading to loss of boost.
blackb1ade
Post by blackb1ade » Wed Jun 06, 2007 9:29 pm
Definite issue - limiter is only at 155 from stock IIRC - mine breeezes straight past 140 like it's not even there.....err 'allegedly'
Avus B5 RS4 with St.3 MTM
Users browsing this forum: No registered users and 71 guests
