Heavy Clutch on quick change?
Hi Guys,
Been meaning to ask the dealer about this but just not had any time recently. My car went in for the TMC and at the same time, they upgraded my car software. I am not sure if this caused the problem or the problem was there before, but when I am in quick change mode and tramp down on the clutch, it gets extremely hard. This is quite disconcerting when you are trying to overtake and need to clear 2 gears only to have the clutch become extremely heavy.
Has anyone else experienced this? Any idea what could be causing it?
Thanks.
Thanks.
RE: Heavy Clutch on quick change?
you mean like 5th to third?
RS4 B7 Sedan 2006 Phantom Black
Solar Panel Sunroof / I pod
MODS- H+R Springs / H+R Front/Rear Sway Full Milltek This week
Current B7 RS4 1/4 mile record holder 12.883
E46 M3 SMG sold / But not forgotten
Chrysler Crossfire Roadster - sold
No, not necessarily ... it happens on any gear change. What seems to trigger it is how hard and how fast you depress the clutch. The faster and harder you do it, then harder it becomes ...
- alex_123_fra
Re: RE: Heavy Clutch on quick change?
Saint, sorry to hear about your clutch issue. I hope it is not this but on the earlier cars there is a known issue with the clutch vacuum assist line which controls clutch actuation. As the line collapses, it squeezes off the vacuum at the same time as you're depressing the pedal. This causes the pedal to go stiff.Saint wrote:No, not necessarily ... it happens on any gear change. What seems to trigger it is how hard and how fast you depress the clutch. The faster and harder you do it, then harder it becomes ...
You can test for the problem by letting the car sit at idle and then press the clutch repeatedly as fast as you can. If the pedal stiffens, you have the issue.
I would avoid driving too spiritedly unless you get audi to check it and ensure your car has the more updated vacuum line. If this isn't the problem, it would be interesting if you report back with details.
Best of luck.
Alex
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
Clutch Vacuum Line
I'd second Alex. Sounds like the clutch vacuum line collapsing.
To test, put your car in neutral and depress your clutch multiple times as fast as you can. If it stiffens, you have the problem.
RE: Clutch Vacuum Line
can this problem be fixed under warrenty?
- alex_123_fra
Re: RE: Clutch Vacuum Line
Sykotoy, if the issue is with the vacuum line, the dealer has to fix it under warranty with the updated one. This isn't a "wear and tear" issue as audi already know.sykotoy wrote:can this problem be fixed under warrenty?
RE: Re: RE: Clutch Vacuum Line
Guys, thanks for the heads up. You've got me worried now. Must get on to the dealer asap. I have tried this test previously and it consistently happens.
Guys, took it to the dealer and confirmed that this was the problem. They have sorted it out under warranty and it drives fantastic again. I printed out this thread and left it in the car just so that they were clear on what to do.
Thanks for your help!!!!
Much appreciated.
S.
Much appreciated.
S.
Re: RE: Re: RE: Clutch Vacuum Line
Saint, the guys on here are SOOOO helpful, I have had ALL my questions answered and I now in tern help answer others questions, where would we be without these great forums.Saint wrote:Guys, took it to the dealer and confirmed that this was the problem. They have sorted it out under warranty and it drives fantastic again. I printed out this thread and left it in the car just so that they were clear on what to do.
Much appreciated.
S.
- alex_123_fra
Glad we could help Saint. Enjoy the car
I agree with John, this forum is great and everyone shares knowledge so readily. I really don't know what people did pre-internet era. The dealers must have been quite a lot busier!
Users browsing this forum: Google Adsense [Bot] and 785 guests
