Light Weight Flywheel...
Hi Guys,
Well it is quite clear this is the next step for me... wondering what others out there were running, where you sourced it and how much it cost.
Suggestions welcome.
Cheers,
Cheers,
RE: Light Weight Flywheel...
Hi,
I think vastperformance do one which looks quite good. Also, www.clutchmasters.com is pretty popular I think -
replaceable steel friction liner and steel ring gear.
HTH
Jon
HTH
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
tanoga do one for £450 can't rember if that includes VAT, I've got one and it is much lighter then the standard one.
1.9TDI A6 are sh*t wrong forum
Re: Light Weight Flywheel...
getting mine from mrc, let u know my opinion in a week or soZeroK66 wrote:Hi Guys,
Cheers,
noggy blue s4, mildly modded
RE: Re: Light Weight Flywheel...
when i sold my car i sold LWFW and LW pulleys to MRC..also thing about removing your viscous fan assembly and fitting an electric 1..the more you can remove from the engine that uses the engine to turn it the better and easier the engine will rev and the less power your'll lose..
you have a big space where your IC's were so why not think about feeding more cold air into your airbox from the front..
seal up the holes and get a direct feed in..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
anyone hearing "bonnet slot" here ... ?seal up the holes and get a direct feed in..
Deus ex machina
Agreed - I've been thinking about ways of getting an extra cold-air feed into the stock air-box by using some tubing routed from the front grilles (like on your M5 woody) - but there's so little room in the bloody engine bay to get the tubing in .... grrrr!anything is better than havin warm air sucked in from the area near the exhaust..
Deus ex machina
so off topic leon and im sorry for that..B5RS4 bumper style grills with a cold air feed taken into the airbox..or merc diesel louvres in front wong just beyond the indicator feeding the airbox...
the last idea i toyed with was to run some tubing from the front side of the air box behind the head light into the top of the IC shroud..as the air came into cool the IC's it would also be sucked into the airbox...
020 83353032
020 83353032
AMD do a lightweight aluminium flywheel @ £349 + VAT.
http://www.amdtechnik.com/product.detai ... nceID=5176
Have you spoken to Doug? Would be interesting to see which one he recommends or has had experiences with...
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
