Re: Calipers.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
rsdreamer
Re: Calipers.
Post by rsdreamer » Tue May 22, 2007 8:52 am
Hi to all.
I know there is a massive amount of information on the forum about brake types / kits etc, but can anyone can answer the following please.
Whats the best caliper to use on a Facelift B5 S4, running standard 17" rims with standard discs ?
My apologies in advance for trawling this one up again, but every time I do a search, I end up with a whole mismatch of info.
If anyone knows the answer, are there any part numbers available.
Regards,
rsdreamer
Ads4
RE: Re: Calipers.
Post by Ads4 » Tue May 22, 2007 8:58 am
I think APRacing do a calliper/ disc set up that can be used with 17s. Pretty sure that's what Jimbogrey uses...
Adam.
MRC B5 S4 Avant.
MarkB
RE: Re: Calipers.
Post by MarkB » Tue May 22, 2007 9:03 am
Yes he does. Hi-spec also and the Porsche setup as DaveT and GrahamS4 run
Mark
GrahamS4
RE: Re: Calipers.
Post by GrahamS4 » Tue May 22, 2007 9:12 am
Note the disks are changed also rsdreamer. Although possible using custom caliper brackets, using upgraded calipers on stock disks not a popular upgrade.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
MarkB
RE: Re: Calipers.
Post by MarkB » Tue May 22, 2007 9:15 am
Ah yes. I missed that. I don't know of any off the shelf kits for larger callipers on standard disc's
The setup Jimbo is running is also expensive disc's
Mark
ChipHazzard
RE: Re: Calipers.
Post by ChipHazzard » Tue May 22, 2007 9:18 am
I've gone for stock calipers with EBC turbo grooved disc's which feel fine so far, If you change to Hi-Spec calipers you will need to change the disc's as well as that was the only thing that stopped me from going for a hi-spec steup was down to the cost at the time
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
nickb834
Re: RE: Re: Calipers.
Post by nickb834 » Tue May 22, 2007 9:21 am
MarkB wrote:Yes he does. Hi-spec also and the Porsche setup as DaveT and GrahamS4 run
IIRC the Porsche setup is 993 Turbo with 332 mil discs?
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
DavidT
RE: Re: RE: Re: Calipers.
Post by DavidT » Tue May 22, 2007 5:38 pm
The 993tt ones are 322 x 32 I think.
Increasing pad are is one thing that will help with fade resistance, but the main thing is getting thicker discs that can get the heat away. Thats why upgrade kits are a set of: discs, callipers & pads.
jeffw
Post by jeffw » Tue May 22, 2007 6:03 pm
HiSpec do a 335x32 set-up for 17" rims which is what I have run for the last 4.5 years. I'm going to change my discs to 360x32 now that I have 18" rims.
