How To Reset ECU?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ZeroK66
How To Reset ECU?
Post by ZeroK66 » Fri May 18, 2007 9:49 am
Hi Guys,
Correct me if I am wrong... but while driving around the ECU adapts to your conditions (talking about ignition timing). If I wanted to re-set the ECU so it re-learnt how I would I do this?
Just wondering if I stuck some octane booster in the tank would I see any improvement if the ECU is holding back the timing based on experience on previous tanks of fuel.
I could of course just disconnect the battery, but I thought there may be a better way to do it is all.
Cheers,
viperbl
RE: How To Reset ECU?
Post by viperbl » Fri May 18, 2007 12:08 pm
I think if you clear faults in the ECU/engine with VAG Com it will clear the adaptive figures as well, but, not sure if you can reset faults (if there are none) if you know what I mean!!
RS4 B5 Saloon8) with 750+ bhp :D
MarkB
Post by MarkB » Fri May 18, 2007 1:17 pm
Yes you can
Mark
ajsl
Post by ajsl » Thu Jun 21, 2007 5:56 pm
Is it confirmed that if you clear engine/ECU faults then the adaptive settings get cleared too?
shineydave
Post by shineydave » Thu Jun 21, 2007 6:19 pm
i cleared a couple of codes on monday then went to check my fuel trims only to find them reading 0.0 so it would seem that a scan and code clearing session does clear the adaptive values
Dave
DavidT
Post by DavidT » Thu Jun 21, 2007 6:39 pm
I was told there are some the ecu remembers even after the ECU has been disconnected for an hour & the fault codes have been reset. Mihnea is the man to answer I think.
PetrolDave
Re: How To Reset ECU?
Post by PetrolDave » Thu Jun 21, 2007 7:02 pm
ZeroK66 wrote:Hi Guys,
On a B6 S4 you reset this by turning the ignition on, NOT starting the engine and pressing the throttle pedal fully down for several seconds. You would hear the DBW motors clicking and whirring, and when that stopped take your foot off the pedal and start the engine.
Return to “DTC / VCDS”
