N75 valve - how does it work
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
MCB
Post by MCB » Wed May 16, 2007 9:25 am
I hake it when we go off topic!
S4B5 Avant
ChipHazzard
Post by ChipHazzard » Wed May 16, 2007 9:27 am
Is there a porpoise to all this banter?
to that matter is there a porpoise to the whale tailed porsche turbot's
Or are we all fishing for sense in a sea of crap
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
S4TAN
Post by S4TAN » Wed May 16, 2007 10:19 am
Back on topic then ...
I've heard it said (in hushed whipsers) that you can put the N75 valve from an S2 in to get more boost ...
Deus ex machina
CliveH
Post by CliveH » Wed May 16, 2007 10:27 am
S4TAN wrote:Back on topic then ...
shall I try it...? or should we rely on MRC's magic...? :lol:
I've also heard, in not so hushed whispers, that if you screw around with the S4 N75 valve, you can get it to dance to all sorts of tunes...know anything about this Jules...?? :shock:
Clive
S4TAN
Post by S4TAN » Wed May 16, 2007 10:51 am
shall I try it...?
Yeah - go on Clive - be a devil!
Ummm ... I may have some familiarity with the matter of which you speak .... :sekret:
Deus ex machina
ChipHazzard
Post by ChipHazzard » Wed May 16, 2007 10:51 am
stop carping on, you'll end up with the N75 screw police after you
FL Noggy S4 Avant
MCB
Post by MCB » Wed May 16, 2007 11:15 am
Yes Clive you should, be interesting to see some before and after logs (With help so I can understand the bl**dy things!) and then carp on about it to us.
Shhhh
S4B5 Avant
ChipHazzard
Post by ChipHazzard » Wed May 16, 2007 11:21 am
I think it might be time to sit back and await with baited breath for the logs to be trawled thru and see if there is a net gain
FL Noggy S4 Avant
MCB
Post by MCB » Wed May 16, 2007 11:22 am
Excellent work there :lol:
S4B5 Avant
ChipHazzard
Post by ChipHazzard » Wed May 16, 2007 11:27 am
this codding can get you hooked
FL Noggy S4 Avant
yorkie
Post by yorkie » Wed May 16, 2007 6:52 pm
I'm Floundering to find any more info on how the Turbots are controlled without it.
I've looked at every Plaice I could find on the web and could only find Red Herrings.
Gonna switch on my Tuna and pump up the Bass as I'm fed up with Carping on.
S4TAN
Post by S4TAN » Wed May 16, 2007 7:07 pm
Yorkie - £10 "star prize" winner!
Deus ex machina
viperbl
Re: RE: N75 valve - how does it work
Post by viperbl » Thu May 17, 2007 9:03 am
saf wrote:Well see. But I believe that you can disconnect or do something to the N75 thus allowing a valet mode like effect where the ECU doesnt deliver the boost. Not sure if it will run like stock in limp mode or not.
I have done this a couple of times when leaving the car places, it reduces it to the min, which is 0.4 bar of boost.
I also had a "faulty" N75 valve just there... after MRC's new map I was running around 1.8 bar ish, which dropped to, at best 1.6 bar. I replaced the N75 valve (with a newer model? two different part numbers, I believe it might be a new verson)
Anyway, straight back up to 1.8 bar ... :D :D
I read somewhere, that this newer model can give 0.2 bar extra by default... have a read of this also ...
RS4 B5 Saloon8) with 750+ bhp :D
S4TAN
RE: Re: RE: N75 valve - how does it work
Post by S4TAN » Thu May 17, 2007 9:55 am
What's the part number of the N75 you put in Viper? I've also experienced similar N75 malarkey (lost a few psi of boost etc so suspected the new N75 i'd put in had gone "faulty")
Also: i looked at the ECS "race" N75 on their website; the table shows it as being incompatible for the S4 - but there's a photo showing an S4/RS4 engine ... so i e-mailed them asking whether it's compatible or not ... they came back with a definite "No" ....
This is why i may experiment with an S2 N75 ... just need to find out which version to get (there are 2 on vag-parts web-site...) ... the S2 N75 is a 'slower' valve (so i'm told by someone in the know)
Deus ex machina
viperbl
Post by viperbl » Thu May 17, 2007 10:00 am
I will pop out at lunchtime and get the number of the new one I put in, and get the number off the older one that I took out tonight ... certainly fixed my problem!
Return to “Audi S and RS Ownership”
