anyone using DBA4000 or 5000?
buzzard
Post by buzzard » Fri May 11, 2007 4:02 pm
as title
are they on stock callipers
rsdreamer
Post by rsdreamer » Fri May 11, 2007 4:50 pm
Buzzard, hi.
I'm using DBA 4000 with stock calipers and redstuff pads.
I've tracked the car based on max five laps per session with no ill effects, and I sprint the car, (one timed lap per session), again with no ill effects.
All I would say is that you should follow the disc and pad bed-in instructions to the letter.
On saying all that, I will probably go for yellow stuff pads next time because I am generating quite a lot of heat.
My set up is never going to be as good as a big brake conversion, but I can compete well with others on track.
For info, next sprint is at Goodwood on 19th May, (Saturday week).
rsdreamer
:yellowrs4:
MarkB
Post by MarkB » Wed May 16, 2007 3:42 pm
I looked at DBA's but unless you are still running 17" wheels I found it cheaper and I hope better to go with the standard B5 RS4 setup
Mark
buzzard
Post by buzzard » Wed May 16, 2007 4:56 pm
yep still 17's
think i'm ordering today
dba look better quality than other brands i have gone with
with a good quality disc and pad this standard calliper set up should be ok for fast road.(afterall it was designed for the A8)
if i go ko4 and do some traking then that is a different matter
thanks for input though.
S4 B5 long gone
S4 B8 Stage 2
