Since putting everthing back together the car has been overboosting. This weekend I thought I found the problem in the guise of a torn throttle body boot.
Replaced this and things were a little better but still overboosting.
Next I replaced the MAF and then the N75 valve but still the problem persists.
On the way home yesterday I thought I would run a few tests on VAG-COM.
The car is boosting to 2540 mbar! and then the ecu shuts the boost down.
Ok so next test, I unplugged the N75 and carried on the journey home, the car was running a lot flatter as expected but then after clearing the maximum boost limit exceeded code down ...... WOW
The car is now boosting to and holding 2500 mbar (1.5bar boost) and is going like a rocket.
As good as this is I cant help feeling that something is going to break.
My conclusions at the moment is that there is a leak somewhere between the N75 and actuators which is acting like one of those boost bleed valves or a problem with the actuators themselves.
Anyone got any other suggestions ideas that could be causing this?
In the meantime im awfully tempted to chuck it on the rollers to see what it is pulling at 1.5 bar
