DTS snapped
CliveH
DTS snapped
Post by CliveH » Mon May 07, 2007 12:44 pm
Well...you know those security posts which stop people parking where they shouldn't...
I drove over one of those (it was down at the time :lol: and I was supposed to be parking there!) and the parking spot was on a bit of a slope, and you guessed it, the DTS fouled on the end of the bloody post...! :bash:
I didn't think much of it at the time, other than "it's about time I raised the suspension up by 10mm", as the underside of the car is no stranger to speed bumps, etc. :oops:
However, the next day I noticed quite a pronounced change in the engine note when under load (bit like after fitting a K&N cone filter to a Saxo), so I jacked it up expecting to find a split in one of the downpipes or something, but the cause is a clean break in the DTS at one side. It seems the disconnected piece is vibrating and carrying the noise...nice if u wanna compete with the boy racers, but not my cuppa tea... :roll:
So, my question is : am I likely to do any damage by driving it around until I get round to fitting a replacement? The piece which connects to the transmission is still firmly connected and attached to (most of) the main bar.
Clive
s4-99
Post by s4-99 » Mon May 07, 2007 12:51 pm
sorry to hear that m8. It must have been a hard knock to cause it to snap? How low is your car by the way?
Hmmm, its fast but is it fast enough!!!
DavidT
Post by DavidT » Mon May 07, 2007 1:10 pm
Yep, that is some going Clive :shock:
I can't see it taking any harm until you replace it, unless you hit something else hard :(
derdle
Post by derdle » Mon May 07, 2007 1:12 pm
Since the DTS is an aftermarket addition I can't see that any damage can result...bit like it not being there before you fitted it surely?
I didn't think it was actually attached to the transmission, just merely a support under the gearbox?
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
saf
Post by saf » Mon May 07, 2007 1:23 pm
Theres a DTS group buy going on if you want to replace it soon.
Need 4 more guys.
Those things are supposed to be tough. Mist have taken a lot of force to crack it.
I too cant see any damage resulting from driving around with it for a while.
S4TAN
Post by S4TAN » Mon May 07, 2007 1:38 pm
Bummer Clive! Know what you mean - mine bears a few nice deep gauges and lots of scratches thanks to over-zealous speed bumps and the like ... my rubber bush is starting to perish a bit too ... :shock:
Deus ex machina
nickb834
Post by nickb834 » Mon May 07, 2007 1:46 pm
Hi Clive,
Personally I'd get this snapped one tig welded up, by the sounds of it you like dragging your cars guts over bumps alot :-P
I'd keep this tigged one on till it's wrecked otherwise you'll end up with DTS's as a consumable item.
Whadda ya think?
If you're lucky Chris might have a TIG welding set at work!
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
grizz
Post by grizz » Mon May 07, 2007 2:08 pm
clive , which part has broken ? is it the main bar ? if so i would do as nickb834 suggests and get it welded up.
Unit 20
0151 3366888
shineydave
Post by shineydave » Mon May 07, 2007 6:01 pm
I've got a MIG but no Argon or alloy wire, bummer
Dave
s4woody
Post by s4woody » Mon May 07, 2007 6:10 pm
arhh the terms of endearment are so nice on this site...poor clive has been away for a while,breaks his DTS and gets called a bummer all in the same month...
GARTH ROAD MOT CENTRE LTD
020 83353032
S4TAN
Post by S4TAN » Mon May 07, 2007 6:19 pm
Ah yes, but .... is he a bummer tied to a tree though ... ?
Deus ex machina
shineydave
Post by shineydave » Mon May 07, 2007 7:42 pm
..........well it is a VERY dodgy 'tache
Dave
CliveH
Post by CliveH » Mon May 07, 2007 7:58 pm
Thanks for the advice (and abuse!) guys :thumbs:
My thinking was that the (OEM) bar that was removed when fitting the DTS was giving some support to the transmission (and the fitting instructions tell you to support it before removing any bolts), but now I come to look at the instructions, the bar doesn't seem to be supporting anything at all, unless the gear box just sits on the OEM bar?
Welding seems to be a good solution though - not being an expert in such matters, how well does aluminium weld up?
Clive
CliveH
Where did it break?
Post by CliveH » Mon May 07, 2007 8:01 pm
@grizz, this is where it's snapped...
Clive
CliveH
RE: Where did it break?
Post by CliveH » Mon May 07, 2007 8:07 pm
As regards how easily it snapped, being a parking space, I must have been doing all of 2 or 3mph... :shock:
However, once the crunch engaged, there was little space for manoeuvre, other than reverse back out so the nasty little pole did get another pop at the undercarriage... :lol: so be warned :roll:
Clive
