Does anyone know which channel/block i can look at to check the accuracy of the oil temp guage?
I don't suspect any problems but would like to know how accurate it is.
TIA
Checking oil temp
RE: Checking oil temp
Usually the instrument cluster shows the oil temperture in MVB 050.3.
Sebastian @ Ross-Tech.com
Re: RE: Checking oil temp
Can you elaborate? Me not understand!!Sebastian wrote:Usually the instrument cluster shows the oil temperture in MVB 050.3.
B5 S4
RE: Re: RE: Checking oil temp
Go into instruments which is module 17, then measuring block 050. One temp is water, the other is oil.
