rs4 recaro into s4 saloon
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
ash318
Post by ash318 » Thu May 03, 2007 3:40 pm
I know its been asked before but cant find post,will a rs4 interior go into a s4, mainly the rear seats and rear door cards.
jeffw
RE: rs4 recaro into s4 saloon
Post by jeffw » Thu May 03, 2007 4:33 pm
Rear seats have the wrong catch arrangement for the Saloon.
Blue_Thunder
Post by Blue_Thunder » Thu May 03, 2007 6:07 pm
I'm giving it a go very soon. For the upper, the latches for the seat backs will need to be moved and re-welded on the car. If that doesn't work out, i'm going to take the rears and my original cloth rears to a local upholsterer and get them to make me a frankenstein seat (saloon bases with recaro foam and leather grafted on).
DavidT
Post by DavidT » Thu May 03, 2007 6:10 pm
Good luck with that, let us know how you get on.
Does anyone have any EKTA type piccies of the difference ?
And do the difference vary - pre/post facelift etc. ?
Blue_Thunder
Post by Blue_Thunder » Thu May 03, 2007 6:20 pm
Even if it takes a spirited session with a nail gun and many rolls of gaffer tape to hold them in place... they are going to fit!
:audibash:
ash318
Post by ash318 » Thu May 03, 2007 6:58 pm
thanks guys if welding and upholstery is needed i think i will give it a miss
fletchie55
Post by fletchie55 » Fri May 04, 2007 9:03 am
sounds like a lot of work when you can just buy some recaros for the saloon & not have to mess around with them.
Blue_Thunder
Post by Blue_Thunder » Fri May 04, 2007 10:05 am
Good luck finding them!
Blue_Thunder
Post by Blue_Thunder » Fri May 25, 2007 9:34 pm
Well, i'm nearly there. Got some 4.7 Ohm resistors off fleabay and cleared the airbag warning code using Vagcom. Sorted!
As for the rears, it looks easier than I thought. The base is a straight swap. The uprights bolt in the same way as the saloon.
There are only two issues.
1) The side bolsters for the avant don't have an 'overhang' meaning there will be a gap of about 2"x3" underneath the seatbelt at the back. I can live with that.
2) The latch arrangement is different, but it should be a much easier job than I had earlier anticipated (welding/etc.). The saloon latch will come off with a couple of torx bolts.
Should be a piece of :piss: to fabricate something to bolt into it's place. When I get it done, i'll post up the dimensions incase someone else fancies taking on the task. Reckon a local welders should be able to sort it out for chump change.
h8cak
Post by h8cak » Fri May 25, 2007 11:45 pm
Looking forward to seeing the results. I have wanted to do this for a while. Cant u just use the original saloon rear side bolsters?
Wide Body S4
Blue_Thunder
Post by Blue_Thunder » Fri May 25, 2007 11:54 pm
You can if the original interior isn't grey cloth!
h8cak
Post by h8cak » Sat May 26, 2007 12:06 am
Ahh i c!! Bugger :( Agreed it might look a bit funny :)
Wide Body S4
saf
Post by saf » Sat May 26, 2007 12:46 am
Whats the difference between an RS4 and S4 recaro interior.
I have the S4 recaro interior and cant tell the difference between them apart one.
The only differecnce I see is the RS4 emblem embosssed into the seats.
h8cak
Post by h8cak » Sat May 26, 2007 1:55 pm
And the way that the rear seats latch on the RS4 is diff from the saloon.
Wide Body S4
jase0851
Post by jase0851 » Wed Jun 06, 2007 3:23 pm
i have b6 recaro,s in my car not an easy fit
Users browsing this forum: No registered users and 152 guests
