Part no requests
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
nickb834
Part no requests
Post by nickb834 » Fri Apr 13, 2007 8:06 pm
I'm trying to locate some part numbers for the stock B5 RS4 brake discs.
I'm not after the VAG part numbers but rather the Brembo part no's.
AFAIK the calipers are made by Brembo, well mine have Brembo stamped / cast into the caliper body.
Is it Brembo that make the discs or someone else?
Any idea's - forum search doesn't reveal much :-(
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up ;-)
yorkie
RE: Part no requests
Post by yorkie » Fri Apr 13, 2007 9:00 pm
Etka list 8DO615301P left and 8DO615302B right - special order oem only
nickb834
Post by nickb834 » Fri Apr 13, 2007 11:50 pm
Cheers Yorkie, but them's the VAG group no's that I'm not after :-P
I'm hoping to find out who makes them for VAG and see if can source anywhere else.
Basically, I object to paying 300+ vat for a pair of discs with only 1mm of wear each side before new ones are required....
Perhaps I'm just a tight northerner :-)
nickb834
Post by nickb834 » Sat Apr 14, 2007 12:35 am
looks like my only option is the GMBH drilled disks - ah well, £300 plus vat it is then
eddiecrawford
Post by eddiecrawford » Tue Apr 17, 2007 5:15 pm
why can you not get the old ones machined, esp if its only 1mm wear(!)
mad-for-tar
Post by mad-for-tar » Tue Apr 17, 2007 8:23 pm
I have a Brembo catalogue on CD at work. I can look up the part numbers tomorrow for you when I get to work, if thats any good...
There are 2 tools you need in life: WD-40 and Duct Tape.
If it moves and it should'nt, use the Duct Tape
If it doesn't move and it should, use the WD-40
mad-for-tar
Post by mad-for-tar » Wed Apr 18, 2007 8:12 am
Just had a look and it does'nt list anything for the RS4. Thats buggered that plan up! :(
nickb834
Post by nickb834 » Wed Apr 18, 2007 1:07 pm
eddiecrawford wrote:why can you not get the old ones machined, esp if its only 1mm wear(!)
I don't have any old ones! That's why!
Basically funds don't stretch to RS4 B7 Discs / Calipers etc etc I got a pair of B5 RS4 calipers for practically nowt and now just need disks.
Seeing as the disks don't have alot of wear in them and they ain't exactly cheap AND I'm into my first year of ownership - there's a potential for me to have to change these discs maybe twice more (do 18k miles a year - mostly cross country no motorways) over the life of the car I'll feel a bit ill knowing I spent a grand on brake discs.
It gets hard to justify RS4 disks when the stock S4 disks can be had for a ton.
eddiecrawford
Post by eddiecrawford » Thu Apr 19, 2007 10:38 am
doh! :oops:
" don't have any old ones! That's why! "
