Tyre pressure sensors
Is it possible to swap the tyre pressure sensors between wheels? I've a spare wheel without one and a damaged wheel with one and would like to move it over.
Teutonic_Tamer
RE: Tyre pressure sensors
Dunno - that's an interesting question.
Though the handbook actually recommends swapping the front wheels to the rear, and vice-versa - so I would presume it should automatically "detect" the correct sensors, when you recalibrate the TPMS in the DIS.
BTW, does the DIS actually tell you which particular wheel is going flat, or is it a generic type of "get your fat ar$e out and check all your pressures"
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Re: RE: Tyre pressure sensors
It's the generic oneTeutonic_Tamer wrote:BTW, does the DIS actually tell you which particular wheel is going flat, or is it a generic type of "get your fat ar$e out and check all your pressures"![]()
So make sure you've got a pressure guage in the car as it's not easy to see the flat one with the low profile tyres.
Cheers,
Daz
Audi RS4 Cabriolet with added Milltek - Gone
Daz
RE: Re: RE: Tyre pressure sensors
Does this mean you need to install a set onto your track day wheels and tyres?
Never argue with an idiot, they will drag you down to their level and beat you with experience.
The sensors are behind the valve stem. You can swap them easily, but obviously have to remove or break beed on tyre,.Easy for tyre shop. Have had done. Cheers
Teutonic_Tamer
OK, thanks.Daz wrote:It's the generic oneTeutonic_Tamer wrote:BTW, does the DIS actually tell you which particular wheel is going flat, or is it a generic type of "get your fat ar$e out and check all your pressures"![]()
I always keep my own pressure gauge in the car anyway, and I usually check them every 2 weeks or so.Daz wrote:So make sure you've got a pressure guage in the car as it's not easy to see the flat one with the low profile tyres.
Rgds
Do you know what the part number is?
Would rather just put new ones in the trackday wheels and tyres, saves the hassle and they can't cost that much can they?
about 100 sheets each
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
I will have 5 or so spare TPM sensors available by the end of this week, some have done about 2K miles and some are brand new. Let me know if you are interested in them. they are sensors and valves.
- SimonS4MTM
- Top Gear
I have bucket loads of them here
I'm after one simon if your bucket is of the bargain variety!
Present:...
Past:
Past:
Users browsing this forum: Bing [Bot] and 300 guests
