Logging etc
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
GrahamS4
Logging etc
Post by GrahamS4 » Tue Apr 03, 2007 12:42 pm
Hi,
Just a quickie about logging and being new to vagcom in general.
Say I am logging Block 003 and maybe another with a view to some FATS times.
Does the log keep logging (within reason) until I say stop or is there a (again within reason) limitation?
Rather than keep stopping in between a session of say 3 runs, what I am thinking of is prepare logging, drive in 3rd gear under 4200rpm. Hit enter key to start logging as starting first run. When 6500rpm is passed, hit enter key to insert a mark. Keep driving, slow to 3rd gear well under 4200rpm, start accelerating and hit enter to enter a mark signifying start of new run.
Just trying to figure out how you guys do it?
Any other tips, must tries to explore?
Regards
Graham
jfeb
RE: Logging etc
Post by jfeb » Tue Apr 03, 2007 12:54 pm
It keeps logging until you stop it - you can let it run for 20 mins+ np problem. Worst case is that the file would have too many rows to import in to Excel (>60k). I would start the log and let it run until you have finished messing about. I don't even bother making marks - you can find the relevant points in Excel easily enough by searching for WOT in the data.
GrahamS4
RE: Logging etc
Post by GrahamS4 » Tue Apr 03, 2007 2:15 pm
Throttle angle 100% - yes I see. Thanks for your help.
Return to “DTC / VCDS”
