Exhaust gas temp sensor
My newly aquired Vag-Com and shiny new laptop are telling me that the offending item above on bank one is shorting to live.
Is this serious and would it make the car go into limp mode?
If it is in limp mode all I can say is "God help me" as she scares me now!
Is this an urgent need to fix or f**k it just clear the code and hope for the best.
RE: Exhaust gas temp sensor
If you clear it and it stays away all good. If it comes back I would get it fixed ASAP
Mark
Thanks, will she do damage then young sur?
TTFN
TTFN
I'd be interested to know if it puts it into limp mode when it has this error flagged. I might need to replace mine. It's flagging 17862 - Exhaust Gas Temp Sensor 1 (G235) - I've cleared it & will recheck later but anyone know off hand if that's the 'hard' one or the 'easy' one?
98/Missano/Bose/Carbon
- ChipHazzard
AFAIK it doesnt put the car into limp mode as I need to get mine done as it's been dead for a few weeks now, if you get one from a stealer it's about £140 + the dreaded vat and VAG parts are £100 + vat & delivery, the part number is 078919529F
IIRC G235 is the drivers side sensor which I guess will be easy if you take the airbox out, although I'm sure somebody will correct me
HTH
Mike
HTH
Mike
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
you dnt need the airbox out to do any of them..yes the drivers 1 is easyest..it will deffo make the car run underpowered so a sort of limp mode..
@chip..if ya want a hand fitting it let me no..se,london/kent aint that far and i have the tools to do them..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I don't suppose anyone has a nice write up about how to do it ... for the not very spanner handy
- ChipHazzard
I might just take you up on that offer woody, even though you have defected over to the dark side, I'm only 2 mins from jtn 1a on the orbital car park
FL Noggy S4 Avant
i have family in dartford which i go and see often.mite have to meet up and sort out ya little EGT prob...
020 83353032
020 83353032
when my egt sensors went the car went straight into limp mode untill they were changed. if yours is in limp mode it will only give .4 bar boost instead of .8 and it makes one hell of a diference.
