I want to be able to fit (on a temporary/easily removable basis) a four point harness belt for track days, not particularly for safety but because it is so much easier to drive well when one is fully located in the seat. I note that in the rear seats, in an ideal location, are the fittings for what I assume are the child seat. Are these stressed for adult belt attachments? are there adaptors available to allow the fitting of seat belt brackets? If not what has anyone done? I saw very recently a picture in a UK car magazine, which has an RS4 avant on long term test, where they had fitted four point harnesses. Does any one remember which magazine it was so I can contact them?
colin
fitting full harness belts
RE: fitting full harness belts
It's of course your choice but the common advice is only fit a full harness if you've got a roll cage. If you're unfortunate enough to roll it then the odds on snapping your neck as the roof collapses are a lot higher.
Have you considered the cheap and effective alternative : a CG Lock ?
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
- quattrosteph
Harness
In EVO april 2007 there is an advert for an harness you can fit on your seat, no need bolts at all !!! Looks really good: £90 !!
It is call: Schroth QuickFit asm, schroth.com
Thinking to buy one for myself...
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
Re: Harness
Like scotty says, harnesses are not recommended unless you have a full cage as the will hold you upright in the seat and if you roll, the roof is likely to 'move'quattrosteph wrote:In EVO april 2007 there is an advert for an harness you can fit on your seat, no need bolts at all !!! Looks really good: £90 !!
- quattrosteph
Harness
Very good point
