Where can I get 18 inch S4 B6 reps from to fit my B5 S4?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
saf
Post by saf » Sun Mar 04, 2007 3:33 pm
Hi guys,
Been away for a bit.
Where can I get some B^ S4 reps from to fit my S4.
I want 18 inch size,.
These reps need to be able to accomodate the RS4 discs and rs6 calipers.
Ive been told that I will need a 3mm spacer to accomodate that brake setup, but im not sure if that varies on the manufacturer of the wheels or not.
So far I cant find anywhere that does reps. I know the Audi original B6 S wheels need a 10 mm spacer. I dont want to be putting a 10 mm spacer. 5mm or less will be just right.
Any info will be greatly appreciated.
s4yogi
Post by s4yogi » Sun Mar 04, 2007 5:25 pm
got mine from here last week very good http://bestwheelsandtyres.co.uk/
go to wheels, collection then audi then they are collection 114 :D
S4TAN
Post by S4TAN » Sun Mar 04, 2007 8:23 pm
Good find s4yogi - nice price too. :thumbs:
Deus ex machina
gavsteryoung
Post by gavsteryoung » Mon Mar 05, 2007 5:11 pm
S4 Yogi,
Do you have a pic of them on your car? I dont think there the same as the B6 Avus alloys... these are more like the orginal B5 S4 Alloys.....
I have not seen anywhere doing B6/B7 Avus Reps..... yet! ;-)
s4yogi
Post by s4yogi » Mon Mar 05, 2007 7:06 pm
yes they are the same as the B6 wheels just dont lokk like it on the website
DSC00186 small.jpg (91.37 KiB) Viewed 1269 times
S4PJH
Post by S4PJH » Tue Mar 06, 2007 8:29 pm
This place also has them but there a little more pricey
http://www.performancealloys.com
saf
Post by saf » Sat Mar 10, 2007 4:37 am
Thanks guys.
Very very good find.
Much appreciated. Been busy and forgot all about the message I put up.
S4yogi , do your wheels have the design where the middle of the spoke sticks out or goes in? (To eliminate curbing problems I hope they go in)
Thanks again
Also do the ones you bought from there clear the RS6 calipers and RS4 B7 discs?
s4yogi
Post by s4yogi » Sat Mar 10, 2007 4:37 pm
Hi the spokes go in. I think you need a 3mm spacer to clear the front rs6 brakes, I think SATAN has this setup on his car maybe he can help
william64
Post by william64 » Sat Mar 10, 2007 11:04 pm
saf wrote:Thanks guys.
Thanks again
look at your old posts
The answers probably the same as the first time you asked
saf
Post by saf » Sat Mar 10, 2007 11:05 pm
Thanks mate
I hope that they are the same design as Satans setup. Just incase the spoe thickness might be different.
Ive tried many combinations with no luck. I guess 3mm spacers are fine. They dont pop out too much.
So if the spokes go in unlike the B5 ones, does that mean they pretty hard to curb the centre of the wheels, only the outside it prone to curbing. Going to be getting 235 40 18 profile.
saf
Post by saf » Sat Mar 10, 2007 11:09 pm
Thanks again
Just making sure mate.
I went and bought some wheels off a guy that said they were RS6 reps. When I got home they didnt fit. Althought they were exactly the same wheels as Tarten rob used on his beast a while back, the spoke design were different. I guess its all about who makes them
I dont want to get home and then try the wheels on a car with the rs6 setup to find I have 4 giant peper weights. Not a good idea.
So for the third time im trying to find some wheels, I want to make sure all is well.
S4TAN
Post by S4TAN » Sun Mar 11, 2007 3:42 pm
Yep - I've got B6 S4 replica wheels ... what are the offset of the versions you bought s4yogi? Mine are ET35, just wondered if the ones you got are the same ...
Deus ex machina
s4yogi
Post by s4yogi » Sun Mar 11, 2007 9:23 pm
Yea mine are ET35 to
saf
Post by saf » Mon Mar 12, 2007 3:14 pm
I contacted best wheels and tyres and been told they do the B6 wheels but only et45.
Then I was told that they do an ET35 after they did some checking but its called a double drilled wheel.
Is there any problems with having this kind of wheel and if I used a 3mm spacer, I shouldnt have a problem with the rs6 calipers right?
Thanks again
Yogi did you buy yours as a double drileld wheel (something about there being 10 bolt holes instead of 5)? The guy said to me that theres some notes on there in the last 4 weeks where someone had et 35's made or machined or something. Was that you?
S4TAN
Post by S4TAN » Mon Mar 12, 2007 3:18 pm
I think 'double-drilled' refers to the fact that it's a replica that has extra wheel nut holes drilled in to fit a variety of cars ... (or something like that)
Deus ex machina
Users browsing this forum: No registered users and 65 guests
