Where do you connect your det can's to on your S4 ??
S2tuner
Trader (Expired)
RE: Re: RE: Where do you connect your det can
Post by S2tuner » Thu Mar 08, 2007 9:18 pm
Never seen that sort of codes before and in general if they can happen, they won't be caused by a faulty knock sensor or a faulty MAF... some people here can read in between the lines, so be my guests ...
This is really scary.
DavidT
Re: RE: Re: RE: Where do you connect your det can
Post by DavidT » Thu Mar 08, 2007 9:46 pm
NotNormal wrote:Yeah, it's sweet as a nut - has not got any knock
Do you know who put the map on and when ? If so, did it run OK at first ?
NotNormal
Post by NotNormal » Thu Mar 08, 2007 9:59 pm
The map was put on @ Quattronics - by Kev from Revo.
I've always said that it's not felt right - from about 1.5-2 weeks after the map was flashed in .
I'v tried the Revo map in all modes,95/98/100 ron and their version of the 'stock' map - which is alot less than the real stock map :roll: , but it's all the same :(
DavidT
RE: Re: RE: Re: RE: Where do you connect your det can
Post by DavidT » Thu Mar 08, 2007 10:02 pm
Is it possible that there are a number of versions of the software and they flashed your car with the wrong one ?
NotNormal
Re: RE: Re: RE: Re: RE: Where do you connect your det can
Post by NotNormal » Thu Mar 08, 2007 10:23 pm
DavidT wrote:Is it possible that there are a number of versions of the software and they flashed your car with the wrong one ?
I dunno, it's a question that has already been posed to Revo along with the map + the vag com fault colde and the values of readings taken whilst running live
Doug_S2
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Where do you connect your det ca
Post by Doug_S2 » Thu Mar 08, 2007 11:13 pm
knock sensors maxed out is really bad news. I wouldn't even drive the car.
http://www.MRCtuning.com
NotNormal
Post by NotNormal » Thu Mar 08, 2007 11:36 pm
Doug_S2 wrote:knock sensors maxed out is really bad news. I wouldn't even drive the car.
The car was only driven for testing once we realised that the det was so severe. It has the stock audi map in the ecu again now and all is well and fine in the knock stakes (just alittle flat in the frist couple of gears) :D
Doug_S2
Trader (Expired)
Post by Doug_S2 » Fri Mar 09, 2007 12:04 am
that is good then. Do you want to try a map that doesn't max out the knock sensors?
NotNormal
Post by NotNormal » Fri Mar 09, 2007 12:09 am
Doug_S2 wrote:that is good then. Do you want to try a map that doesn't max out the knock sensors?
I've been looking on your site, and i do like the sound of your map. Only thing is your in banbury and i'm in lincoln - might cause an issue :(
tartan_rob
Post by tartan_rob » Fri Mar 09, 2007 1:00 pm
I was not having a go, I was simply saying that you need to know what you are doing with these cars and assumed (perhaps incorrectly) that as you have not done the tuning yourself and indeed have a problem you cannot resolve you perhaps are a little underqualified to be listening for and 100% identifing pinking. I am an engineer and I would not be comfortable "listening" myself...
On a lighter note there is another post on this forum about tuning options, some guy has had problems with a Revo map, it may be related.
Hope you get a good result in the end and no offence meant.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: Google Adsense [Bot] and 36 guests
