Beta 702 is out
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
MarkB
Beta 702 is out
Post by MarkB » Wed Mar 07, 2007 9:33 am
I've just noticed Beta 702 is out. It has a handy function of being able to save a set of advanced measuring blocks. Something I've been wanting!
The only thing I'm worried about is the fact it requires a firmware update that isn't compatible with the old version. So I assume you will have to continue using the beta until the full release version is out
Mark
CliveH
RE: Beta 702 is out
Post by CliveH » Wed Mar 07, 2007 10:40 am
Actually, there's lots of new goodies in there Mark - well spotted :thumbs:
However, it says "Required for Vista 64" and "Recommended for Vista 32" - presumably it will run on XP OK?
Clive
MarkB
RE: Beta 702 is out
Post by MarkB » Wed Mar 07, 2007 10:47 am
I guess so?
Mark
PetrolDave
RE: Beta 702 is out
Post by PetrolDave » Wed Mar 07, 2007 12:59 pm
I'm running 607.3 on Vista without problems.
Think I'll stick with that until there's a 7xx non-Beta - because of the loss of backward compatibility.
MarkB
Re: RE: Beta 702 is out
Post by MarkB » Wed Mar 07, 2007 1:04 pm
PetrolDave wrote:Think I'll stick with that until there's a 7xx non-Beta - because of the loss of backward compatibility.
I'm probably going to do the same if that's the case
Mark
CliveH
RE: Re: RE: Beta 702 is out
Post by CliveH » Wed Mar 07, 2007 1:08 pm
Me too - seems logical.
I wonder if Uwe can add anything?
Clive
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Wed Mar 07, 2007 6:20 pm
We've had hundreds of people download the Beta and no reports of major problems. There have been some minor issues, all fixed very quickly which is why the current version is 702.2.
Anyway, I think it's reasonably safe to use. But it is a Beta and whether any individual decides to use it is completely up to him -- Release 607.3 will continue to be fully supported until 7xx is becomes a full Release.
-Uwe-
CliveH
Post by CliveH » Wed Mar 07, 2007 6:45 pm
Many thanks for your prompt input Uwe :thumbs:
Is the firmware update a one way thing (ie irreversible)?
Clive
PhilT
RS246.com
Post by PhilT » Thu Mar 08, 2007 10:44 am
Clive, what firmware are you on about? Vag-Com is software....?
MarkB
Post by MarkB » Thu Mar 08, 2007 10:58 am
PhilT wrote:Clive, what firmware are you on about? Vag-Com is software....?
But the lead has firmware in it to act as the key
Mark
CliveH
Post by CliveH » Thu Mar 08, 2007 11:06 am
Thanks Mark :thumbs:
Yes, the "dongle" in the Ross-Tech cable has firmware which, amongst other things, validates the Vagcom software licence.
Release 7 apparently updates the firmware in the dongle.
Clive
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Fri Mar 09, 2007 12:18 am
The firmware does a lot more than just the licensing. It buffers data, it converts data to CAN format, etc.
-Uwe-
PetrolDave
Post by PetrolDave » Fri Mar 09, 2007 11:34 am
Since 702 is now up to 702.3 I'm going to take the plunge and start using it.
I always get nervous about version 1 of any software, especially when I lose backwards compatibility. But I'm happy to join the VAG-COM beta testers now.
MarkB
Post by MarkB » Fri Mar 09, 2007 11:38 am
I feel the need to use it for the reason I mentioned at the start. Uwe says it seems to be OK so thats OK with me :)
Mark
PetrolDave
Post by PetrolDave » Fri Mar 09, 2007 2:00 pm
It was a combination of Uwe's words and the speed that Ross-Tech fixed a problem that Craigyb found that convinced me.
Words AND deeds!
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 96 guests
