DVD SatNav from CD/Tyres
alangjones
Post by alangjones » Wed Mar 07, 2007 11:05 am
Has anyone upgraded their CD SatNav plus to the DVD unit. Apparently run out A6's and late Allroads had the DVD system. Is it just a matter of taking out the old unit ,unplugging and re installing the dash unit or are other bits and wiring needed. Anyone in the South East able to do this? Just had leaking H20 rad changed under extended warranty. Re Tyres F1's are fine but using Contis as they were cheaper and they grip well. Were bout 100 each fitted. Also on 4th windscreen in 3 years.!!
rs999 on Blues and 2's
RSVI
RE: DVD SatNav from CD/Tyres
Post by RSVI » Wed Mar 07, 2007 11:10 am
Your question i can't answer but it has been discussed over the last month or two.
Your tyres though! £100 a corner :o Is this for the 19"?
And 4th windscreen in 3 years. Front or back and why replaced?
Image Image Image
bobjebb
Post by bobjebb » Wed Mar 07, 2007 11:46 am
Craigyb seems to be the only one who can do this for you, he's in Manchester. I've not seen RNS-D but the E is better by all accounts. Still don't understand why the people who make these things don't know how to fit them, but there we go. Craig I understand does a lot of work for Audi, he must be making a fortune.
Just had a chip in my second windscreen in 6 months. But then again, I'm an unlucky b@stard.
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Golfather
Post by Golfather » Wed Mar 07, 2007 12:27 pm
Yes RNS-E units can be fitted, very straightforward, literally plug and play.
Just need the necessary wiring adaptors to fit.
I have one if you need it.
Can also provide instructions if you fancy doing this yourself.
alangjones
Tyres/w/screen
Post by alangjones » Wed Mar 07, 2007 2:43 pm
Tyres were 19 x 255 35's and got from Treads in Ramsgate, Mick is the Man. Re w/screens , all front with bad chips through outer laminate and one blew a 9" crack on a very hot day owing to trapped moisture. Oddly the bonnet has not a stone chip but the front valance is like a smallpox victim. My BMW E34 M5 had one w/screen in 245000 miles yet the bonnet was so pocked and had 2 resprays because of chips
Rek
RE: Tyres/w/screen
Post by Rek » Thu Mar 08, 2007 5:31 pm
I'm interested in converting to DVD and don't mind taking a crack at it myself so long as its not rocket science. Let me know what you want for it.
RSVI
Re: RE: Tyres/w/screen
Post by RSVI » Thu Mar 08, 2007 6:41 pm
Rek wrote:I'm interested in converting to DVD and don't mind taking a crack at it myself so long as its not rocket science. Let me know what you want for it.
who's selling it?
Image Image Image
Rek
RE: Re: RE: Tyres/w/screen
Post by Rek » Thu Mar 08, 2007 11:10 pm
See further up this post.
RSVI
Post by RSVI » Thu Mar 08, 2007 11:33 pm
sorry, crossed wires ;) thought it was the RSN-E someone was selling, not the wiring adapter. :D
Image Image Image
Rek
Post by Rek » Fri Mar 09, 2007 7:49 am
Take a look on eBay. There are quite a few for sale, but beware the ones from Latvia and Lithuania
jonathanb
Post by jonathanb » Fri Mar 09, 2007 9:21 am
You just need to be alittle careful. The transfer of the unit is relativeley easy although I understand the cars electronic brain needs a bit of a tickle to get all the functionality but the existing tv tuner that you have will not work and this needs replacing together with appropriate wiring loom which is a pain. If you ae not near Craigyb ( i.e. in the south) then there is a place called audiotronics (ithink) in West yfleet who will install all the bits though they do not supply the units. RNS-E functionality is loads better and Sat nav more accurate e.g it actualy identifies Kingston on thames as a place rather than as a part of Richmond!!
Jonathan
peterb
Post by peterb » Mon Mar 12, 2007 2:24 pm
If you search the forums, you will find that I did this upgrade myself, with very little problem. If anyone, within reach of Reading, needs a hand, I'm quite happy to assist.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
SteveH
Post by SteveH » Mon Mar 12, 2007 10:38 pm
Did you do TV tuner also Peter?
Present:...
Past:
peterb
Post by peterb » Mon Apr 02, 2007 9:31 am
SteveH wrote:Did you do TV tuner also Peter?
Ooops.. not been on the board for a little while!
Yes, I did swap the TV tuner as well!
Suzuki Carry 660
Users browsing this forum: No registered users and 205 guests
