Ferodo DS2500 Brake pads
Hi....
Does anyone know whether these brake pads will fit on stock calipers for 17" wheels.
Have tried everywhere, but no-one appears to know. Seems most retailers are aware of these pads fitting S3's or s6's but not S4's.
Also, anyone know where I can hold of a set of these if there are any specifically for a standard S4 ?
Mucho gracias
Mucho gracias
- ChipHazzard
RE: Ferodo DS2500 Brake pads
S4Jem,
It might be worth giving Hi-spec a call as I discussed several options with them and I have a feeling that the ferodo pads we're rather expensive. I was going to put EBC yellows on mine but unfortunatly EBC havnt got any front pads available and it was going to be a month before they had any.
Just my thoughts
Mike
Just my thoughts
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
- ChipHazzard
Mark
I had a long chat with Hi-spec about which pads to use and as I'm putting EBC turbo grooved disc's on EBC was the obvious choice then came the choice of yellow and red and yellow was decided on because of the performance of our cars, Unfortunatly they wont have any yellows for the front for at least a month as EBC have none in stock, so i had to go for red as i need to change my disc's as the rears have corroded and the fronts are nicely worn
Just my tuppance worth
Mike
Mike
FL Noggy S4 Avant
I take it all back on the EBC yellows. It was Pagid yellows that were bad http://www.rs246.com/index.php?name=PNp ... ic&t=56317
Mark
Spent some time at Hi Spec on saturday and after a lot of time considering the options, have decided to go with:-
OEM Discs @ £40 each and have these machine grooved by Hi Spec @ £25 a disc
Cannot get hold of the Ferodo pads for a S4, so have decided to go for the EBC Yellow pads option...the discs and pads seem to be the best compromise.
Was very tempted though to go with their monster 4/6 pot set up...what a lovely piece of kit to hold in your hands and in different colours !!!
. Bit cheeky of them, but I managed to get away without buying them
- ChipHazzard
BRETTCOLLINS
- 5th Gear
[/quote]
Have the monster 4 pot kit on my car. they are excellent.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
- ChipHazzard
S4Jem,
I ordered front & rear EBC turbo grooved disc's & EBC yellows, when I chased them up to find out whe they would be in I was told that EBC had no Yellows pads for ours and that it would be a month before EBC made another batch, hence I ended up going for the reds as they were available.
As a side note I've just fitted My disc's & pads today so it's bed in time & so far so good, although I found one of the rubber dust covers on the rear calipers has a hole it in so gotta replace that as well now.
Next time your over let me give me a shout It'll be nice to say Hi
FL Noggy S4 Avant
Users browsing this forum: Google Adsense [Bot] and 71 guests
