NOS sprayed onto the Intercooler
viperbl
Post by viperbl » Tue Feb 27, 2007 3:14 pm
How about that for an idea? Rather that using water, use NOS to freeze the intercooler ...
Never thought about this or knew it was possible?
check out near the bottom of this link for the one they used on this car... ahmm, beast!
http://www.discovery-automotive.com/por ... ntent&id=4
RS4 B5 Saloon8) with 750+ bhp :D
viperbl
RE: NOS sprayed onto the Intercooler
Post by viperbl » Tue Feb 27, 2007 3:21 pm
And would you maybe need different maps for when you where using it and not using it??
I am thinking if the air is very cold you put further advance and get more power, but surly you could not run that much advance if you did have it cold all the time ...
william64
Post by william64 » Wed Feb 28, 2007 8:49 am
Co2 would be cheaper
DavidT
Post by DavidT » Wed Feb 28, 2007 9:12 am
Quite common I think. stevett has it on his TT and was pressing it while we were queuing at Santa Pod - barsteward :)
Nige_RS4
Post by Nige_RS4 » Wed Feb 28, 2007 9:18 am
C02 would probably get into the engine via the airbox on the S4/RS4 and extinguish the spark plug flame!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
fil
Post by fil » Wed Feb 28, 2007 7:27 pm
cooling the intercoolers a good idea, but surely you'd see better power gains if you actally used the NOS as intended, and fed it to the engine?
99 S4 minging blue avant
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Feb 28, 2007 8:44 pm
steve uses nos into the engine and he can purge it onto the IC before a run.
http://www.MRCtuning.com
viperbl
Re: RE: NOS sprayed onto the Intercooler
Post by viperbl » Wed Feb 28, 2007 8:56 pm
Doug_S2 wrote:steve uses nos into the engine and he can purge it onto the IC before a run.
How much power can the RS4 engine as it is hold?
I always thought NOS into the engine was cheetin :P, maybe ok for getting rid of turbo lag, but then again, nos into the intercooler maybe a little bit of a waste of money ... I mean, Doug, how much extra power could realistically be had by doing this??
Doug_S2
Trader (Expired)
RE: Re: RE: NOS sprayed onto the Intercooler
Post by Doug_S2 » Wed Feb 28, 2007 9:02 pm
as long as the ecu is happy with the nos you run I do not see why you cannot run 100bhp extra with no problems.
I know of a mapped s4 with 200 shot of nos on it.
dummi
Post by dummi » Wed Feb 28, 2007 10:26 pm
i remember a discussion about co2 it turns to carbonic acid? with water vapour on the intercoolers and eats them? i don't know if thats fact or just forum chatter
william64
Post by william64 » Wed Feb 28, 2007 11:39 pm
How about nitrogen then?
Then run it on methanol burns a lot cooler than petrol, you will need huge injectors to get if correct?
DavidT
Post by DavidT » Wed Feb 28, 2007 11:39 pm
Err, what is purge please matey?
h8cak
Post by h8cak » Thu Mar 01, 2007 12:19 am
I think he means he has the option which switches the nitrous to the intercooler instead of the engine for a few seconds?
Wide Body S4
fil
Post by fil » Thu Mar 01, 2007 2:49 pm
purging no2 came originally from the older american systems, you vent / purge the system, as this no2 lines were too big and it turned to liquid, so was no good, you purge this off before your about to use the system, so you get the spray of gas and not liquid.
all tho im no expect, you need to have a read over at www.wizardsofnos.com still have and used to run one off there systems on my old xr4x4, no need for purging so no wasted gas
Users browsing this forum: No registered users and 39 guests
