Update for Sat/Nav+
cpt_splash
Update for Sat/Nav+
Post by cpt_splash » Wed Feb 21, 2007 9:07 pm
I just bought a new CD for UK & Ireland 2007 for my Navigation Plus DX system in my 2000 RS4. I bought the version with the iTMC for updated traffic reports. This did not work in my system. Do I need a software update, or do I need to buy the version with iTMC? Thanks in advance. Graham
B5 RS4 - RS6 Calipers/B7 RS4 Discs, H&R ARB's, MRC Custom Remap, RS246 Sticker!! SOLD!!
Jarv
Post by Jarv » Wed Feb 21, 2007 9:57 pm
Is this the one you bought:
http://www.navshop.com/en/product/unite ... 3280/101/1
It's the one I bought about three weeks ago, stuck it in and it worked. Is your tuner working OK? The iTMC reports are received via Classic FM, which it tunes into in the background.
Mike
Q7
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 11:21 pm
Yes, it is the same one in your link. It siad that it could not read the CD. I put the old 2002 version back in and it worked fine again. :evil:
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 11:22 pm
Do I need to have Classic FM running first when I put the CD in? I can't believe that you have to do that....
craigyb
Post by craigyb » Wed Feb 21, 2007 11:48 pm
Do you have the RNS-C and not the D?
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 11:53 pm
How would I find out? It is fitted to a 2000 X reg RS4.
Jarv
Post by Jarv » Wed Feb 21, 2007 11:59 pm
No, you don't need Classic FM running at all. You're in safe hands with Craig, he knows his stuff.
Mike
Q7
Dippy
Post by Dippy » Thu Feb 22, 2007 1:25 pm
RS4 should have RNS-D if it was an OEM fit.
2001 Silver S4 Avant
PetrolDave
Re: Update for Sat/Nav+
Post by PetrolDave » Thu Feb 22, 2007 4:24 pm
cpt_splash wrote:This did not work in my system.
What was the exact error message you got?
Carps
RE: Re: Update for Sat/Nav+
Post by Carps » Thu Feb 22, 2007 10:30 pm
I had a similar issue recently. It would read my old disc, but not my new one.
I fixed it when I pulled the navi unit and cleaned the laser. It's been fine ever since.
Might be worth a try...
cpt_splash
Post by cpt_splash » Fri Feb 23, 2007 1:18 am
The error message said that the "CD could not be read. Please insert correct CD". Not very helpful!!! Problem was that as the CD would not read, no functions would work except eject CD. Once the old one went in, it was fine. Arrghh!!!
cpt_splash
Post by cpt_splash » Fri Feb 23, 2007 1:20 am
cpt_splash wrote:The error message said that the "CD could not be read. Please insert correct CD". Not very helpful!!! Problem was that as the CD would not read, no functions would work except eject CD. Once the old one went in, it was fine. Arrghh!!!
How did you clean the laser?
Carps
Post by Carps » Fri Feb 23, 2007 10:24 am
To clean the laser you need to pull the navi unit from the dash and then use a cotton bud and alcohol (medical - not Vodka !) down the access hole in the top of the case.
Maybe better/less effort to try a cleaning CD first ?
Return to “Electrical”
