If some out there (with factory xenons) is bored and fancies an excuse to spend 10 minutes in their car playing with their headlights, I have a request...
Can you please take notes of when the self levelling ritual kicks in ?
Options are:
1/ lights off, turn ignition on
2/ lights on, turn ignition on
3/ igntion on, turn lights on
If they only cycle when the light switch is actually turned on (ie, 3), then do they do it every time or just once for each time the ignition is turned on ?
Cheers in advance.
Andy
Xenon headlamp self levelling ritual...
- shineydave
RE: Xenon headlamp self levelling ritual...
ok, i am actually sad enough to go out and try this
ignition on then lights on, self levels
leave ignition on, turn off lights and back on, no self level
turn off ignition and lights, turn on lights then turn on ignition, self levels
so it would seem like they self level at every restart of the ignition
Dave
Cheers for that.
When you turned the ignition on, did you start the engine or jsut have it in the on position ?
Andy
Andy
- shineydave
just in the on position, what can i say, i'm from Yorkshire and starting it up costs money, every pounds a prisoner, lol
Dave
Cool. Thanks for that.
I had some issues on my Passat W8 which I thought I had sorted with VAG-COM - this info confirms I have
Thanks again
Thanks again
