RNS D coding problem
jonathanb
Post by jonathanb » Wed Feb 21, 2007 10:17 pm
Just sold my RNS-D from my RS6 to a chap on Ebay. He appears to be having a problem getting the radio code to be accepted. All the numbers match the radio serial number and the chasis number so the head unit is the correct one for the code. Anyone else experienced this as a problem previously.
Kind regards
Jonathan
shineydave
RE: RNS D coding problem
Post by shineydave » Wed Feb 21, 2007 10:25 pm
is it not accepting the code or is he getting "safe" in the display?
i'm not entirely sure but i think these are two seperate issues. if he's getting "safe" it could be he hasn't connected a supply to the "safe" terminal on the back of the Nav-Plus. i forget which terminal it is and nav-plus.com is down at the moment so i can't check, maybe craig will be along shortly with an answer
Dave
craigyb
Post by craigyb » Wed Feb 21, 2007 11:49 pm
It will display safe unless you link the "SAFE" wire to +12V
jonathanb
Post by jonathanb » Fri Feb 23, 2007 7:04 pm
Thnaks for your help chaps
Jonathan
Return to “Electrical”
