Hi,
Does anyone know if 19" x 9" alloys (with offset of 30) will go on the s6 (v8) without any problems?
19" x 9" alloys
RE: 19" x 9" alloys
Hi standard rs6 19x9 wheels have an offset of 35 so offset 30 wheels would sit 5mm further out I think it would be fairly tight in the arches.
2000 S6 avant
Nicking my look!
Hello fella, haven't seen you on here for a while. I'm just looking at a set of 9J 18's with a 20et and I've been told they will fit. They are OES and I might get them for less than £250 with tyres!!!!
They have a tiny, tiny flat spot on the inner rim. Do you think that'll be a problem? I think it should be ok as the outer rim is in great condition.
Give me a ring when you fancy,
Northern Monkey.
Northern Monkey.
RE: Nicking my look!
They should be ok , Most large alloys end up wiyh a small flay spot. g
Unit 20
0151 3366888
0151 3366888
