Breaking questiion, (not the 600 bhp ;) )
RSVI
Post by RSVI » Wed Feb 14, 2007 11:09 am
I was lucky enough to make a journey to the south coast yesterday and because it was something i had to pick up from a workshop and get back soon i have to be quick.
A lot of the roads were "A roads" with some "B roads"
I noticed after a lot of breaking they didn't have the same kind of grip as when cooler.
As far as I'm aware they are std pads and drilled disks.
Who's upgraded there pads but kept the same discs?
How much better are they when using the breaks allot?
Are they still good when cold?
Do they wear the disc out allot quicker?
Are they more "squeaky" than std?
What are they and would you get them again?
Oh...... so many questions :roll:
TIA
Image Image Image
mbedford
Post by mbedford » Thu Feb 15, 2007 12:16 am
I'm using ebc redstuff ceramic pads and they are definately more resistant to fade than the o.e pads and there is no squeal at low speeds. However if you use them hard they are noisier than the standard pads and rumble quite loudly, but they still work even at the smoking stage.
RSVI
Post by RSVI » Thu Feb 15, 2007 12:35 am
Thanks.
EBC it is then. Unless someone else comes up with some thing else.
PMSL....... I remember doing that once :shock: 5hit myself! ! !
Image Image Image
jobg
Post by jobg » Thu Feb 15, 2007 10:39 am
I use Pagid blue. Very similar in behaviour as the standard pads, but without the fading. Disc wear is about the same as the standard pads as well.
By the way, it looks like DBA will release brake discs for the RS6 very shortly........
partyboy1101
Post by partyboy1101 » Mon Feb 19, 2007 6:43 pm
Try Ferodo DS2500
bogie
Post by bogie » Tue Feb 20, 2007 1:49 am
Who's upgraded there pads but kept the same discs? yes
How much better are they when using the breaks allot? ..hard to say -better initial bite, and no fade under hard road use
Are they still good when cold? Yes
Do they wear the disc out allot quicker? difficult to tell yet
Are they more "squeaky" than std? a little bit when new/not used for a while...not excessive though and goes away after a couple of uses
What are they and would you get them again? yes - the only pad I run on all cars for road/track
bear in mind (as I found out) you will need some 'blanking plugs' so you dont get the brake worn sensor on the DIS - the Pagids dont come with the sensors so keep your old wires/plugs and cut the wires, solder the leads together and put the 'blank' plug back on the sensor wires .....thanks to Rupert who sent me a spare set after the dustbin men took mine away ! :)
cheers
bogie
1998 S4 2.7 (MRC stage 1) gone
2003 RS6 Avant (ebony black, AMD remap) - sadly gone
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 238 guests
