Has anyone uprated the ARB in an early 1999 S4, I have tried to get one via AMD but the one sent to them was for a later MY and did not fit.
Does the RS4 ARB fit the S4 ?
1999 S4 ARB
1999 S4 ARB
Prawn
Prawn
Re: 1999 S4 ARB
Prawn, were you uprating the front or rear ARB (or both)? I understand that a stiffer front will reduce understeer and a stiffer rear will promote oversteer. They only replace the rear one on the RS4 GmbH kit. Anyone got one sitting in the garage (or even a std RS4 ARB)?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: 1999 S4 ARB
Increasing the stiffness of the ARB at one end will increase the grip at the other so...
Stiffer front ARB = more rear end grip
Stiffer Rear ARB = more front end grip
And less roll of course
Re: 1999 S4 ARB
Currently just looking at the front but would probably do both if I could
Prawn
Prawn
Re: 1999 S4 ARB
Jeff, I stand corrected, you are quite right ...
Shaun, do you not suffer from understeer in fast corners ? Surely replacing the front ARB will make the understeer worse ? I was thinking of replacing the front only, but having read Jeffs post and done a bit of research on the web, it would sound like the rear ARB would be the obvious choice to reduce understeer ?
Thoughts ?
Thoughts ?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: 1999 S4 ARB
I also feel that the rear ARB is going to help the front end grip better, however I was assured by AMD that the front was the way to go.
TBO i was not convinced but agreed to try the front ARB, as it could be returned if no good.
Are the front and rear ARB from the RS4 thicker/stiffer than the S4 ?, if so these may be a good option.
Prawn
Prawn
