I've broke my car :(
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Post by MarkB » Tue Feb 06, 2007 9:18 am
Rich, Do you know yet what damage has been done?
Mark
viperbl
Post by viperbl » Tue Feb 06, 2007 9:36 am
MarkB wrote:Rich, Do you know yet what damage has been done?
Not yet, I will give the garage until lunchtime before giving them a buzz, but I suspect if they had had a chance to look they would have called me and out me out of this misery!
MarkB
Post by MarkB » Tue Feb 06, 2007 9:37 am
Fingers crossed :?
Mark
viperbl
Post by viperbl » Tue Feb 06, 2007 12:08 pm
Latest, Spoke to garage, they have done a compression test on the engine and everything checks out ok, so at the moment its looking like a turbo.
They are gonna take a look at the turbo's this afternoon, and according to them, depending on what side it is might they be able to remove the turbo without removing the engine? I always thoughts it was an engine out job to do any turbo???
MarkB
Post by MarkB » Tue Feb 06, 2007 12:11 pm
It's been a long debate about engine out or not.
Mark
MCB
Post by MCB » Tue Feb 06, 2007 1:32 pm
Sorry to hear about you prob Rich, hope it is not a turbo and not to expensive to get it sorted.
S4B5 Avant
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Feb 06, 2007 2:46 pm
bad luck rich.
I bet you have bent a shaft in a turbo due to downpipes touching the ground.
Time for those RS6 turbos!
http://www.MRCtuning.com
viperbl
Post by viperbl » Tue Feb 06, 2007 2:48 pm
Doug_S2 wrote:bad luck rich.
LOL! Doug, I am in the processes of writting you an email to that effect :shock:
ZeroK66
Post by ZeroK66 » Wed Feb 07, 2007 2:27 pm
D'oh... that possible? OUCH! I assume the shunt can un-balance the turbo while spinning and cause it to bend? A bit scary... maybe I should not be visiting IOM! :o
DavidT
Post by DavidT » Wed Feb 07, 2007 2:53 pm
I don't think you would go fast enough for it to matter Leon :shock: :wink:
ZeroK66
Post by ZeroK66 » Wed Feb 07, 2007 7:18 pm
cheeky sod :P
philipwalker
Post by philipwalker » Wed Feb 07, 2007 7:48 pm
Difficult to diagnose without "having a look"
Surely the exhaust flexi would take any impact away from the turbos. This would be obvious (big ding/scrape impact damage) on inspection. The skid pates on the rear of the front subframe should impact before the cats/exhaust. Any noise from the turbo loss of boost etc??
The sump is fairly vulnerable, slight graze would cause a leak and the escaping oil would burn off on the increased exhaust temperature, when accelerating. Leading to smoke. Any spots of oil on the floor? Is the oil smoke coming out of the exhaust or is it external?
http://www.pwmotorsport.com
PW Motorsport
01437 563929
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Feb 07, 2007 8:24 pm
The flexi after the bend at the bottom of the DPs doesn't stop shocks going up the turbo. Seen 2 cars with fooked turbos because of that.
shineydave
Post by shineydave » Wed Feb 07, 2007 8:26 pm
Doug, what where the symptyms when the turbos got triped
Dave
MCB
Post by MCB » Wed Feb 07, 2007 9:35 pm
:wink:
While your having one Dave make mine a large one! :lol:
S4B5 Avant
Users browsing this forum: No registered users and 150 guests
