To VAG-Com users, FATS times database for the Euro S4s
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
DavidT
RE: Re: RE: Re: To VAG-Com users, FATS times database for th
Post by DavidT » Sun Jan 28, 2007 8:52 pm
Very good time Jeff.
How much quicker does it feel now than when it left AmD on K04's ?
jeffw
Post by jeffw » Sun Jan 28, 2007 10:07 pm
There is just an enormous difference ....something like 70BHP difference :)
S4TAN
Post by S4TAN » Sun Jan 28, 2007 10:11 pm
Is that down to the MRC work IYO Jeff?
Deus ex machina
jeffw
Post by jeffw » Sun Jan 28, 2007 10:16 pm
It left AmD with around 365BHP (K04s and Full Milltek with downpipes and AmD map...claimed 400BHP). Since then it's had injectors (700cc) Bosch Fuelpump, new K04s (the old ones melted !) and RS4 IC plus the magic MRC remap to get 443BHP :) or 78BHP
S4TAN
Post by S4TAN » Sun Jan 28, 2007 10:19 pm
Result!
Deus ex machina
DavidT
Re: RE: Re: RE: Re: To VAG-Com users, FATS times database fo
Post by DavidT » Sun Jan 28, 2007 10:30 pm
S4TAN wrote:Result!
Yes, a different car, enough to make you think the cars you pass brake as you pull out. Magic.
S4TAN
RE: Re: RE: Re: RE: Re: To VAG-Com users, FATS times databas
Post by S4TAN » Sun Jan 28, 2007 10:35 pm
... which was nice :)
Deus ex machina
rolskii
Post by rolskii » Sun Feb 04, 2007 1:25 am
Just did mine .....
Times are taken from group 1 .... pasted into the VAST calculator
Time RPM
2.72 3600 <-- below 4200
3.65 4440 <-- above 4200
6.48 5560 <-- below 6500
7.6 6880 <-- above 6500
71% from below4200 to above4200
3.384 interpolated timestamp for 4200
71% from below6500 to above6500
7.278 interpolated timestamp for 6500
FATS: 3.89 :smile_smoking: <-- Time in Seconds from 4200-6500
Half a tank of 97ron..... just me ... nice and cold outside too.. +0.5C
other runs turned out at around 4.3-4.7's -- which is the common medium..
jeffw
Post by jeffw » Sun Feb 04, 2007 8:04 am
I think everyone else is logging Block 003 to get their data....There are large gaps in your data points, around 0.8 secs in each case. Can you try it again with logging on 003 ?
3.89 with a 3750lb (3550lb by itself plus 200lb for fuel and driver) car would equate to 414BHP at the crank which is incredible quick for a K03 car (I assume your still running K03s ?). 4.7 is 343BHP which is very good for a K03 car.
MarkB
Post by MarkB » Sun Feb 04, 2007 9:17 am
He's running K04's
Mark
jeffw
Post by jeffw » Sun Feb 04, 2007 9:35 am
Ahhh....didn't realise. What's the spec then ????
CliveH
Post by CliveH » Sun Feb 04, 2007 10:52 am
Nice times David :thumbs:
Clive
rolskii
Post by rolskii » Sun Feb 04, 2007 12:16 pm
rs4 inj, f/pump, ic's, low comp. head gaskets
k04's, gutted rs4 d/pipes, milltek 3"
modified airbox & mrc map.... rest is s4 bits ... maf, pipework etc... :nodder:
jeffw
Post by jeffw » Sun Feb 04, 2007 12:32 pm
Nice....:)
Can you do some block 003 runs and post them...would be intersted to see how they compare with mine
rolskii
Post by rolskii » Sun Feb 04, 2007 12:43 pm
Sure will do ..... just need a quiet moment ..... sober ...
That was the best run, the others were between 4.3-4.7 ...... but I was trying to blend in w/traffic ... :biggrin2:
Soon as I put fully synth. oil in it I will give it a good beating .... being a numpty I dropped oil/filter and filled the oil up with semi-synth oil ... doh....
so that was the only time I am pushing it till i replenish with some good stuff in the sump .....
Return to “DTC / VCDS”
